sallen pullie
Old Nov 4, 2006 | 04:24 PM
blackhorse05's Avatar
blackhorse05
I ♥ Acer
Default sallen pullie
does anyone have the 5lb pullie of the 05 06 sallen s/c, i believe its the 5 lb, i have the the lower boost package and i ant to go up in boost a little
Old Nov 4, 2006 | 06:24 PM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: sallen pullie
The stock pulley is 4" which is 3.5lbs. Next pulley size is 3.8" which is 5.5lb. If you are going to go through the trouble to change the pulley, change the belt, and retune the car, I would suggest at minimum going to with the 3.6" 7.5lb pulley. There is not going to be enough of a difference between the stock pulley and the 5.5lb pulley for you to really notice other than dyno numbers. Certainly doesn't justify the money spent on the 3.8" pulley. I have a 3.6" pulley laying around that I would sell you. BUT... I am out of the country right now on business and won't be back until Thanksgiving.
If it were me, I would go with minimum the 3.6" 7.5lb or the 3.4" 9.5lb pulley as the next step. You can run 9.5lbs on a stock bottom end with no worries. Just make sure whoever tunes your car knows what they are doing.
Old Nov 4, 2006 | 07:12 PM
Haulupki's Avatar
Haulupki
I'm running the 3.2 pulley. I did experience some slight pinging between 5500 and 6000. The problem seemed to be the fact that I was running the stock exhaust. Once I put the header on, the boost dropped a pound or so, and pinging seems to have disapeared. But what hawgman said is very true. Don't even waste your money or time just droping on size. You won't even notice the difference.
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
96mustanggt46
Jan 12, 2004 02:52 AM
VicsGT
Nov 25, 2003 07:07 PM
skatepony
Jul 30, 2003 10:12 PM
