error dammit error
Old Feb 17, 2007 | 09:29 PM
6marc5's Avatar
6marc5
Default error dammit error
Hello,I have a 05 GT. Does anybody know what this error code is? DTE FLI DATA ERROR It comes on and turns my dash pink, beeps alot and sends my fuel gage to empty even though its slap full.
thanks,6marc5
Old Feb 17, 2007 | 09:35 PM
SRT_what's Avatar
SRT_what
Default RE: error dammit error
Can't say I've heard of that one. Does a CEL accompany it? Try re-setting the ECU and see if it goes away.
Old Feb 17, 2007 | 09:45 PM
wolfey2k's Avatar
wolfey2k
ORIGINAL: 6marc5
thanks,6marc5
I believe that's an internal factory code that only means what it means to the Ford engineers. Could be in your owners manual though.
I see weird error messages like that on my digital readout while I'm uploading a new program to my MCU. That's the only time I see it.
If you don't own a programmer and or haven't reprogrammed your MCU by yourself then I would say you should take it to the dealer and have them re-upload the factory program. That should handle it if it's a simple MCU brain fart. If not, then you'll probably need to have the MCU replaced.
Could be something as simple as a dirty or lose MCU connector. Check under your hood to see if there it's dirty or lose. Check the condition of your wiring to and from the MCU. Make sure it's all good.
Good luck!
Old Feb 17, 2007 | 09:59 PM
6marc5's Avatar
6marc5
nope,no CEL. It just makes noise, turns my dash a nappy pink and empties my fuelgage.The car stills runs fine,no misses or burps or anything. guess I'll be at ford monday morning ,give me a chance to see a 427 roush
Old Feb 17, 2007 | 10:01 PM
6marc5's Avatar
6marc5
Hello, I looked in the manual and it had nada. I haven't messed with the programming at all,guess I'll take it to ford monday. thanks
Old Feb 17, 2007 | 10:15 PM
wolfey2k's Avatar
wolfey2k
ORIGINAL: 6marc5
Ah hah, actually it sounds like your MCU is just fine.
I have a feeling you have a lose connection or bad dash control module or perhaps afaulty voltage control unit thatis suppose to feedx volts to the dash and digital control module.
Look under yourdash and see if you can find any loseconnections. Also look at your fuse panel and see if there is alose or cracked fuse that feeds power to the dash control module. You'll have to pulland visually check the fuse to see if it'scracked. Ifit looks funny in any way compared to agood fuse, replace it.
Good luck!
Old Feb 18, 2007 | 10:22 PM
6marc5's Avatar
6marc5
Thanks for the thoughts wolfey2k,i'll poke around and see what I can find.
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
zanemoseley
Sep 6, 2015 12:58 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
