GEARS FOR AUTO TRANS.?????????
Hey people. Looking for a little help. I own a 06 gt vert. auto trans. I went to buy gears for it 3.73 and my gear guy said no way go with the 4.10 gears. I told him i drive it everyday on the freeway at about 80 mph and he said they would be fine. Needless to say i left with no gears. Can anyone tell me what your using in your auto trans cars. I read on here before and all the auto guys were runnin 3.73 gears are you now running 4.10's. many thanks.
RE: GEARS FOR AUTO TRANS.?????????
I am running 3.73 gears in my auto and like them fine. I would not recommend 4.10’s if you do a lot of highway driving. With my setup I am at 2500 at 75 mph which is a good RPM, if I had 4.10’s I would be at 2800 and about 3100 at 80 mph. If you want to get a feel for 4.10’s just hit your overdrive off when you are at highway speed and you will be running close to what 4.10’s would feel like.
Earl
Earl
ORIGINAL: retfr8flyr
Earl
Earl
there is no reason to go any taller then 4.10s for a DD the 4.6s are SOHC modular motors, they rev to make power these arent the muscle cars of the 70s, they arent the 5.0s of the 80s
http://www.stangnet.com/Tech-Article...d-Answers.html
i had 3.73's in mine for a while and they were great. 80mph @ 2600rpms. now with 4.30's 65mph @2600rpms. my car ran about the same 1/4 mile times with the 3.73 vs. 4.30 gears although now i run more mph....it's a little backwards but i guess it just put the rpms in the sweet spot when the converter locks in. best e.t. with 3.73's was 12.62@106 then with that same tune and 4.30's i went 12.62@110.2 best. now i have a killer tune and can take advantage of the steeper gears 12.29 at 110.4 N/A so far.
I went with 3.90 Motive gears not bad but if I was to do it again it would be 4.10s. 3.73s is not enough gear for our high reving motors your just not in the power band quick enough.
musnicki
09-23-2015 07:11 AM
