safe mode codes p0446/ p2106 need help
Old Mar 28, 2007 | 04:34 PM
ozan169's Avatar
ozan169
Default safe mode codes p0446/ p2106 need help
hi ppl
my baby stang started going in to safe modelast night these to codes keep on coming up p0446/ p2106 when it gose in to safe mode any ideas ppl i tryed clearing the codes with my sct2 but no luck keeps on coming back. it dose it most when i push me foot to the floor i can drive it if im going slow ???????
thanks
2005 mustang GT auto
Stoptech gt stage 2 braking system
Kenny brown strut tower brace
Bmr rear swaybar
Bmr lower rear control arms
eibach pro kit springs
Bbk airfilter kit
Bbk ceramic short headers
Magnaflow x pipe with racing cats
Magnaflow Cat-Back Exhaust System
Bbk 62mm twin throttle body
Moto blue under drive pulley kit
brentspeed Sct tuner
Ford racing 4.10 gears
Comp cam racing cams stage1
comp cam valve steel retainers
comp cam valve springs
Ford racing cmcv delete kit
tci torque converter 3000stall
Old Mar 28, 2007 | 05:12 PM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: safe mode codes p0446/ p2106 need help
How long since your last mod and what was it? Asking only because I see the throttle body listed in your signature.
The 2106 code is a throttle position sensor code. Also, going to sound like a stupid question, but have you checked your gas cap? The 0446 is Evaporative Emission Control system Purge Control Valve Circuit Shorted. AFAIK two things will cause that, the gas cap being loose, and the control valve being open or faulty. ( the control valve is that thing you don't know what it is on the drivers side strut tower under the hood ). But it could very well be a byproduct of the 2106 code, again leading back to the aftermarket throttle body. So far, pretty much no one has had any luck with the aftermarket throttle bodies.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
guitarman376
Sep 30, 2015 05:54 PM
