Chirping into 2nd Gear
#22
RE: Chirping into 2nd Gear
i've chirped third on a good shift. we don't have concrete down here, just asphalt, on the streets so that could be a factor. i haven't powershifted the car yet but throwing second i get something longer than a squeal but no smoke or squirreliness the car stays straight as an arrow. my car is also 5spd so it's a bit different.
if you're auto the best way to come off the line sideways is with stock tires, 4.10 gears, and a higher stall converter with better torque multiplication.
#23
I hope you realize that this "chirping" only has to do with shock load on the drivetrain. It really doesn't matter how much power you have, it's just a difference in speeds when you suddenly shift and dump the clutch, which is made up for by the tires spinning for a second.
Seriously I can "chirp" 3rd in an 80 hp honda civic.
#26
ORIGINAL: tube
FWD cars do chirp like crazy though. My friends RSX with full exhaust and intake could chirp all the way into 4th.
#27
"Chirping" is for birds, Mustangs don't chirp the tires they smoke'm. From a dead stop without reving the motor I can drop the clutch and burn'em all through first, and all through second gear with ease. I wish I had the kind of traction the OP is complaining about.
#28
With my BC tune even before I got my C&L Racer CAI and acompanied tunes I could get 2nd to chirp HARD and then third a bit. I have the shift pressures upped by 25% on all but 5th gear and it's upped 20%. Stock it probably would have to have bald tires or be on black ice to do that.
#30
Ive chirped 3rd in my car stock but I do have a 5sp. Also ive had traction control cut me off going into 3rd recently. usually when I down shift at 65-70 on the highway traction control will cut me off there too.
