Nitrous
Old Sep 13, 2007 | 11:07 PM
Biggdaddy's Avatar
Biggdaddy
Default Nitrous
All my friends keep telling me that the easiest way get to more power is nitrous. But I do not know anything about nitrous so I am kind of leary about doing it. If some one could tell me a little about it and how it works, I would appreciate it.
Old Sep 14, 2007 | 12:13 AM
disturbed!'s Avatar
disturbed!
Default RE: Nitrous
theres different kinds but the two basic are wet shot and dry shot both are safe depending what you are doing with them. wet shot is more preferd b/c its easier to tune and is a little more safe then a dry shot. as long as your car is tune for a high amount of NO2 which on your motor you can get away with 100hp wet with out tuning but anything over that your pushing it.
also depending if your man. or auto is also a factor in safety gadgets like
-fuel pressure safety switch(FPSS) which will cut the fuel to the the motor if the fuel pressure gets to low.
-window switch which controls what rpm the NO2 will activate and de-activate.
-wot switch or thottle position switch(better) which activates the nitrous at full throttle
and thats really about it
Old Sep 14, 2007 | 12:16 AM
disturbed!'s Avatar
disturbed!
Default RE: Nitrous
anyhow i run nitrous it is safe as long as you know how to use it. but ots not cheap know matter what anyone says. a new kit can run from $560-$1200. and depending where you live you pay nitrous by the LB here in central florida its $3 a LB in cali its around 5 or 6
Old Sep 14, 2007 | 08:53 AM
Biggdaddy's Avatar
Biggdaddy
Default RE: Nitrous
Thanks. I found a kit at DynoTune for $400, it goes from 75-150HP. I have an automatic & I will probably only use about 75-100HP. So do I need to get a FPSS? And what else would you suggest I get with it?
Old Sep 14, 2007 | 09:11 AM
disturbed!'s Avatar
disturbed!
Default RE: Nitrous
well you should get a FPSS, window switch, and throttle position sensor
i know nitrous express makes a nice plate system and comes with everything accept FPSS and window switch
http://www.nitrousexpress.com/Pages/3v_platesystem.htm
but yes you should get the FPSS just in case your fuel pressure drops to low it wont be able to support enough fuel to the motor and the fuel solenoid for the nitrous and can starve your motor and then boom!! no more engine.
Old Sep 14, 2007 | 12:37 PM
PLstang's Avatar
PLstang
Default RE: Nitrous
You may want to check this out:
https://mustangforums.com/m_639288/tm.htm
This will give you the basics of Nitrous. I found it pretty useful when I started out with Nitrous.
Old Sep 14, 2007 | 04:59 PM
Norse1974's Avatar
Norse1974
Default RE: Nitrous
I LOVE MY NO2!!!!!!ALL HAIL THE NO2 GODS!!!!!
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
