Boost management systems
Old Dec 5, 2007 | 10:43 AM
BFMacias's Avatar
BFMacias
Default Boost management systems
Do any of you guys know where to find a boost management system for our Mustangs? How about what they would cost? Also how hard would it be to put on a twin turbo set up?
Old Dec 5, 2007 | 04:25 PM
Simon1's Avatar
Simon1
Default RE: Boost management systems
I use a Greddy Profec-spec2. It works great. They make another that's a little more expensive(600ish) that can do more. It will do everything mine will do, plus ramp in your psi with different gears to maintain traction. There are others.
I was tuning mine last night and got it to spool my turbo .7-.8 psi more between 3-5k rpms. Still peaking at the same PSI.
Old Dec 5, 2007 | 06:29 PM
Stage4's Avatar
Stage4
same controller - love mine. doesn't allow ramp up though, which would be nice
Old Dec 5, 2007 | 09:03 PM
Simon1's Avatar
Simon1
ORIGINAL: Stage4
That's the more expensive model. It was like $200 more. Thought about it then said, I've spent enough.
Old Dec 6, 2007 | 12:42 AM
jdback19's Avatar
jdback19
Good ol manual boost controller zip tied under the hood with a trusted tuner is all I need.
Old Dec 6, 2007 | 01:05 AM
androdz's Avatar
androdz
I ♥ Acer
ORIGINAL: jdback19
Thats great for running but dont expect to run 15lbs daily, What I like about mine is that I can select the psi I want for every gear thus it gives a lot more traction. For example you can run 7psi 1st, 10 psi 2nd, 14 psi 3rd, 20psi 4th-5th etc etc
Andrew
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
