detonation?
Old Dec 21, 2007 | 06:06 PM
frarmar's Avatar
frarmar
Default detonation?
I had my car on the dyno a while back, and it sounded like someone was makin' some popcorn.It only did this inthe upper rpm range.
The thing is i have never heard this while driving down the road. I assume this was detonation. correct? It is not a daily driver so it sits alot. I wonder if this caused some condensation leading to this problem.Also the car was pretty hot don't know if that plays a role or not.I immediately went to my 87 tune.
Any ideas/suggestions?
Thanks.
Old Dec 22, 2007 | 12:01 AM
blackS197's Avatar
blackS197
Default RE: detonation?
I had a predator tuner and had the same problem. pinging at high rpms. I got rid of the tuner and put it back to stock for a while and used 89 octane, no problems. No my car is supercharged with no problems.
Old Dec 22, 2007 | 12:30 PM
crozerstang's Avatar
crozerstang
My car has always had a tendancy to detonate and hotter weather makes it worse. I had a 93 tune and had to take 2 degrees out of the timing to stop it. BP gas is much better than shell in my GT, if I put shell in the ping can come back.
Old Dec 22, 2007 | 09:04 PM
Mpaint99's Avatar
Mpaint99
Unless your car is tuned on the Dyno.The tune you receive in your tuner is a safe generic tune.To get rid of the pings or early detonation they should have fine tuned the tuner to your car while it was on the Dyno.Most of the tuners you buy on line like Brenspeed put a password in so you cant change the tune unless you go back to them.Good Luck. To me it sounds like your car is running to lean at high RPM's.Check your plugs to see if there is any melting happening.This occurs when your car runs to lean causing to run to hot at high RPM's.
Old Dec 23, 2007 | 02:45 AM
frarmar's Avatar
frarmar
I always run bp gas don't really know if it's better than the next......
The thing is i've never heard it just driving down the road. Which makes me nervous, ie is it doing this often and i just don't know it.
Thanks for the advice, i appreciate it.
Old Dec 23, 2007 | 02:28 PM
crozerstang
I wouldn't worry, if it happens you will hear it, if you don't hear then it isn't pinging. Also, the cars computer will modify fueling and timing to prevent most detonation, the controller onlygoes 'open loop' at high rpm and WOT and that's why you only hear a car pinging under those circumstances,
Old Dec 23, 2007 | 02:31 PM
P Zero's Avatar
P Zero
ORIGINAL: frarmar
Thanks.
There's your problem right there.
-P.
Old Dec 24, 2007 | 01:44 AM
frarmar's Avatar
frarmar
Thanks. those last 2 postsmakeme feel a littlebetter.
Now if i could just figure out how to post a pic in my sig....oh well i'll just put one here. lol
jwog666
Dec 27, 2021 08:09 PM
spectreman
Mar 31, 2016 09:26 PM
wildazme
Mar 23, 2006 09:12 PM
91stang331
Jun 8, 2005 12:31 AM
jishead
Feb 15, 2005 08:11 PM
