differential cover
Old Jan 7, 2008 | 11:04 AM
ssemich's Avatar
ssemich
Default differential cover
When putting new gears in do you all change the differential cover to a Ford Racing or T/A aluminum cover? Any benefits in performance from cover, etc or waste of money?
Thanks,
Steve
Old Jan 7, 2008 | 11:07 AM
onederful100's Avatar
onederful100
Default RE: differential cover
i should have done this. no performance benefit, but looks cool, and when changing gears is a good time to change the diff cover too. but if you want performance than it is a waste of money.
Old Jan 7, 2008 | 11:17 AM
techmanBDsStang's Avatar
techmanBDsStang
I replaced mine as well. Another benifit is that if you want to change the fluid for any reason, it comes with a drain plug as where the stock you have to take the cover off and replace the gasket.
Also it is more ridgid and has load bolts to provide more support for the differential bearing caps.
If you choose the FRPP one, you don't need to modify the pan hard bar by getting the relocation bracket. Not sure of the other brands as I used the FRPP.
this one here
http://www.latemodelrestoration.com/...1&comp=LRS
Old Jan 7, 2008 | 11:23 AM
techmanBDsStang
accidently double posted
Old Jan 7, 2008 | 03:25 PM
moosestang's Avatar
moosestang
Are your bolts on your frpp cover rusting? Mine are and i would have thought, they'd use something that didn't rust. I don't think my stock bolts had any rust on them.
ORIGINAL: techmanBDsStang
this one here
Old Jan 7, 2008 | 09:26 PM
techmanBDsStang
[quote]ORIGINAL: moosestang
[quote]
I don't know, I will have to get under and have a look when I get the chance and let you know.
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
