Fail Safe?
Old Jan 23, 2008 | 04:35 PM
Austin@HCM's Avatar
Austin@HCM
Default Fail Safe?
My car continues to fail safe when im driving on the road. I plug in my tuner and it says its throttle/pedal actuator, fan controller, blah blah blah.... Does anyone know how to solve the problem?
[/align]
Old Jan 24, 2008 | 02:14 AM
TheLowsters's Avatar
TheLowsters
Default RE: Fail Safe?
How many trouble codes come up and what are they?
Old Jan 24, 2008 | 02:38 PM
Austin@HCM's Avatar
Austin@HCM
like about 6-7 codes, like i said they are fan controller, throttle/pedal actuator, blah blah
[/align]
Old Jan 24, 2008 | 09:40 PM
Glengemen's Avatar
Glengemen
Generally if you have a situation like that when you get a bunch of codes you will see a common thread between them all. Things like a pinched harness a loose ground, or a loose conector. I don't know how technical you are, but what you can do is look at the schematics. Look at the throttle ckt., fan ckt., and the Blah Blah ckt.(thats a new one to me) and find the common wire or harness. With all your mods it is likly something is amiss. Good luck.
Old Jan 25, 2008 | 01:27 AM
TopNotch06GT's Avatar
TopNotch06GT
it has something to do with the throttle body and the mass air sensor and i cleaned the harness plugs butit only worked for like 3 days and then did it again
[/align]
Old Jan 25, 2008 | 03:41 PM
GT Bob's Avatar
GT Bob
What are the exact codes..numbers and all... The "Blah Blah" stuff is important to know.
Old Jan 25, 2008 | 04:30 PM
Newbreedgt05's Avatar
Newbreedgt05
I got the throttle actuator and some other code on mine in the first year I owned the car. I don't remember the specific trouble codes. It ended up being a problem with the throttle body. I was going to just replace it myself, since I hate the dealership, but decided to have it replaced under warranty. I believe there was a TSB on it.
Old Jan 27, 2008 | 12:45 AM
TopNotch06GT
sounds like my problem
[/align]
Old Jan 29, 2008 | 09:00 PM
Rajun_Cajun's Avatar
Rajun_Cajun
We replaced his throttle body too. Like he said, it ran fine for a couple days, and then it started goin into fail safe again. We even took the damn thing to ford and they couldnt figure out the problem. Here is what we have tried so far...
Replaced TB with another stock unit & cleaned connectors
Cleaned MAF sensor and connectors
Cleaned K&N filter and re-oiled it
As far as I know, it hasnt done it now for 2 days, but we will see.
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
TfcCDR
Sep 14, 2015 12:08 PM
