GEARS
Old May 16, 2008 | 04:25 PM
stealth_GT's Avatar
stealth_GT
Default RE: GEARS
ORIGINAL: thefrantic1
with my 4.30's i tach around 2200rpm at 55. i love them but i have tall wheels 275/35/20's. 4.10's wouldnt of been enough for me.factor in your wheel size also...........................
4:30s?! that's hardcore.
tight bodykit BTW..I really like it!~
Old May 16, 2008 | 05:57 PM
2007REDFIREGT's Avatar
2007REDFIREGT
Default RE: GEARS
ORIGINAL: johnpagenola
50 60 70 80 90 100
Size 235/55 17 4.10 1,724 2,069 2,414 2,759 3,103 3,448
Diameter 27.18 4.30 1,808 2,170 2,532 2,893 3,255 3,616
Size 275/35 20 4.10 1,699 2,039 2,379 2,718 3,058 3,398
Diameter 27.58 4.30 1,782 2,138 2,495 2,851 3,207 3,564
Size 245/45 17 4.10 1,825 2,189 2,554 2,919 3,284 3,649
Diameter 25.68 4.30 1,914 2,296 2,679 3,062 3,444 3,827
Hey John, can youdo one of these charts with 245/40/20 and 255/40/20 using 3.31,3.73, 4.10's.(60,70,80 MPH)THANKS!!
Old May 16, 2008 | 06:06 PM
thefrantic1's Avatar
thefrantic1
Default RE: GEARS
yes mympg has gone from 15 to 12 city and 24 to 21 highway. thanks stealth_GT for the compliment on the car. cant tell by the pic but looks like a stripe on yours right.
Old May 17, 2008 | 02:05 PM
johnpagenola's Avatar
johnpagenola
Default RE: GEARS
2005+ Mustang RPMs in Gear 5 of a Manual Transmission
-------------------------------------- Section=245 Ratio=40 Wheel=20 Diameter=27.72 --------------------------------------
Axle MPH=60 MPH=70 MPH=80
3.31 1,638 1,911 2,184
3.73 1,846 2,153 2,461
4.10 2,029 2,367 2,705
-------------------------------------- Section=255 Ratio=40 Wheel=20 Diameter=28.03 --------------------------------------
3.31 1,619 1,889 2,159
3.73 1,825 2,129 2,433
4.10 2,006 2,340 2,675
-------------------------------------- Section=275 Ratio=35 Wheel=20 Diameter=27.58 --------------------------------------
3.31 1,646 1,920 2,195
3.73 1,855 2,164 2,473
4.10 2,039 2,379 2,718
Old May 17, 2008 | 04:33 PM
2007REDFIREGT
Default RE: GEARS
John, I forgot to tell you to do this using an automatic overdrive tranny if you can using same chart. Thanks for all your help.
Old May 17, 2008 | 04:40 PM
johnpagenola
Default RE: GEARS
2005+ Mustang RPMs in Gear 5 of an Automatic Transmission
Wheel=20 Section=245 Ratio=40 Diameter=27.72 Revs per mile=728 -----------------------------
3.31 1,710 1,995 2,280
3.73 1,927 2,248 2,569
4.10 2,118 2,471 2,824
Wheel=20 Section=255 Ratio=40 Diameter=28.03 Revs per mile=719 -----------------------------
3.31 1,691 1,973 2,254
3.73 1,905 2,223 2,541
4.10 2,094 2,443 2,793
Wheel=20 Section=275 Ratio=35 Diameter=27.58 Revs per mile=731 -----------------------------
3.31 1,719 2,005 2,291
3.73 1,937 2,259 2,582
4.10 2,129 2,484 2,838
Old May 17, 2008 | 06:36 PM
2007REDFIREGT
Default RE: GEARS
Thanks John, I think i'm going 3.73's because my GT is a DD and I run between70 and 80MPH alot. It will still be a big improvement over the 3.31's and still get decent gas mileage.
Old May 17, 2008 | 07:33 PM
johnpagenola
Default RE: GEARS
That makes sense. With the manual transmission, the 5th gear is 0.68, while with the automatic the 5th gear is 0.71. So,
4.10 manual = 3.73 automatic (approximately) and
4.30 manual = 4.10 automatic (almost exactly)
Old May 18, 2008 | 04:26 PM
stealth_GT's Avatar
stealth_GT
Default RE: GEARS
that's sounds pretty good but then again with both cars running equal mods,
say CAI/tuner,axel back exhaust,3k stall converter..which auto would come out on top
in terms of drag racing?
stock tires,one with 3.73s and one with 4.10s?
not sure why but not convinced that 3.73s would be enough for my needs,which is
soley for drag racing.
Old May 19, 2008 | 10:22 AM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
Default RE: GEARS
I'm tacking higher than the chart.
Is it my 285/40/18 tires?
