traction control
well generally no but if your at WOT and tire spin, cut fuel, go lean, and cause damage. not blow up, maybe do a little damge. either way just shuf off TCS. Drive like a man not a girl.
My 2 cents
My 2 cents
yes you are right it is on all the time unless you do the mod where you wire in a realy that shuts it off on start up then you can still turn it back on if you want with the button saves you from turning it off all the time
http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories
ok found the link to the guy who sells the relay have not tried him and know you can pick up the relay at any auto parts store.
Thanks Nuke for finding that link back to the original mod could not remember where i read it.
yeah all it is a relay and a fuse jumper for power but his sounds a little fancier says something about will remember which way you left the switch last i'll have to play around with the electronics been a while since college electronics but wanna work on this and find my paper work i had for sequential tail lights that i put in my 67. think the 100 bucks they get for a simple circuit is crazy think it cost me like 5 bucks to build them.
breaking
Oct 2, 2015 01:27 PM
