need help please ((o2 censor))
Old Jan 15, 2009 | 01:25 PM
biljeek's Avatar
biljeek
Default need help please ((o2 censor))
good day all
recently i installed (( GLOW SHIFT air/fuel gauge )) but it didn't work, i own 07 GT the O2 censor has 4 wires 2 black 1 white and 1 gray i connect the gauge wire to the gray wire of the sensor but didn't worked. the glowshift gauge is designed to work with a narrow band sensors. any help please . should i install another sensor with 2 wires only?
Old Jan 15, 2009 | 07:53 PM
07musclemustang's Avatar
07musclemustang
well if its a norrow band gauge its uselesss.. just a blinky light get a wideband setup
Old Jan 16, 2009 | 12:01 AM
RainsFather's Avatar
RainsFather
Originally Posted by biljeek
good day all
this may be no help to you because it was so long ago since hooking a narrow band gauge up but, on my SHO I believe that the white wire is the signal wire on a 4 wire O2 sensor, but I might be wrong.
yet you quote hood pins as a mod? how is wanting a blinking light any different than shiny metal on your hood? if you want to explain to biljeek the benefits of using a wideband O2 that would be something, but being a douche when someone asks a question is just childish.
Old Jan 16, 2009 | 07:34 PM
07musclemustang
hood pins are functional, especially when you cut a big hole in your hood to make your hood scoop functional.. do you have hood shake? imagine if your hood scoop worked... DICK
Old Jan 16, 2009 | 07:37 PM
07musclemustang
as for the OP you can tap into a wire closer.. under the passenger side carpet there is a wire. i cant remember what one. I say its useless because i had one in my old car and tapped into it there. It was a 04 though. if you go to the Ford Service manuals and search you should be able to find it.
But i stand by my original statment. I had it and thought it was cool for about 3 days then it got annoying and i disconnected and pulled it out. Just thought id give you a heads up.
Ps who names there kid RAIN???
dragman72
Aug 9, 2015 12:54 AM
garyb
May 24, 2008 07:41 AM
mmafan
Apr 1, 2008 10:29 PM
99GTvert
Feb 17, 2007 04:11 PM
