O2 sensor
Old Feb 22, 2009 | 03:37 PM
Bloodrage's Avatar
Bloodrage
Default O2 sensor
Check engine light came on, went to auto zone, they said O2 sensor at bank 1 was slow to respond.Replaced the O2 sensor on the driver side b4 cat.Engine light still on.Anything else I can check?
Old Feb 22, 2009 | 07:28 PM
hammeron's Avatar
hammeron
welcome Bloodrage, bank 1 is the
passenger side. try the 02 before
the cat and let me know what happens.
Old Feb 23, 2009 | 02:10 PM
Bloodrage's Avatar
Bloodrage
A friend of mine suggested I remove the battery cable to reset the cpu.I did and the engine light no longer comes on.
Old Feb 24, 2009 | 01:25 PM
shanec's Avatar
shanec
I had this problem too. But mine problem came up a few weeks after installing longtube headers, which I suspected (at the time) was the problem.
A great thing to try in debugging this is to swap the front driver & passenger side O2 sensors with each other. Then clear your codes. The code will likely come back and hopefully the code is now for the other side - which would mean you simply have a bad O2 sensor. That was the case with me.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
