Nitrous Set-up Help
I plan on putting a zex kit on my car. It's a 2006. I just wanted all you pro's to take a look at the set-up I want to run and tell me what you would change or wouldn't change. Any help and insight is greatly appreciated.
Thanks
Zex kit #82034 (plan on running the 100 shot)
http://www.jegs.com/i/Comp%20Cams/249/82034/10002/-1
Zex Puge Kit
http://www.jegs.com/i/Comp%20Cams/249/82010/10002/-1
Zex Bottle Heater
http://www.jegs.com/i/Comp%20Cams/249/82006/10002/-1
Bottle Opener
http://www.jegs.com/i/Comp%20Cams/249/82009/10002/-1
I'll get a bottle blanket to clean it up in the trunk
Colder Plugs (will these suffice or should I go with something different?)
http://www.jegs.com/i/Comp%20Cams/249/82071-8/10002/-1
I will get the autometer a/f gauge a nirous pressure gauge and mount them on the a-pillar.
Is there anything else I need to do? Will have have fuel issues at all with this set-up?
Thanks for the help!.
Adam
Thanks
Zex Puge Kit
Zex Bottle Heater
Bottle Opener
Adam
It looks like those ZEX plugs aren't made for our year yet. Most people here use these:
Autolite HT0
You'll also need to pull some timing with a 100 shot.
Autolite HT0
Thanks
Thanks
Originally Posted by FoosedStang;
Zex Puge Kit
[url
Zex Puge Kit
[url
http://www.jegs.com/i/Comp%20Cams/249/82010/10002/-1[/url]
Zex Bottle Heater
[url
Zex Bottle Heater
[url
http://www.jegs.com/i/Comp%20Cams/249/82006/10002/-1[/url]
DO NOT wire your heater directly to the battery!!!
Pro: This unit would be a lot easier to hook up.
Bottle Opener
[url
Bottle Opener
[url
http://www.jegs.com/i/Comp%20Cams/249/82009/10002/-1[/url]
[url
[url
http://www.jegs.com/i/Comp%20Cams/249/82071-8/10002/-1[/url]
Adam
Adam
Otherwise, be sure to get an RPM window switch. That way, you don't spray too early and just as importantly, you don't hit the rev limiter when you're spraying. When the later happens, fuel is cut, the system is spraying nitrous and no gasoline and that leads to disaster!
All of the kits I've seen for our cars come with a wide open throttle switch NX, Edelbrock, NOS, Zex, etc. (I'm sure someone will dig one up that doesn't! But most do!) Some kits include a combination window switch/wide open throttle switch. Zex only includes a wide open throttle switch. That's not the safest way.
