Having to add coolant normal ??
Having to add coolant normal ?? UPDATE 3/20/09
I've had to add not a LOT, but quite a bit of collant over the 3 years that i've had the car. And two seperate times i drove a short trip (about 8 miles) and after parking and letting it sit for about five minutes the car dumped about a half gallon of antifreeze. There are no visible leaks as the car is garaged and there are no leaks on the ground yet im still having to add coolant. I drove the car from new york to florida and back over the course of almost two weeks. The night before I left I added coolant while the engine was cold to be right in the middle of the "full cold" range. And i checked again when i got back a few days ago and now the level is right below the "full cold" range... My warranty is up in about 2 months.... any ideas ??
oh ya, the times it dumped coolant and i brought it to the dealer they couldnt find a problem, added coolant and shipped me.
The fact that you are losing this much coolant but actually cant find where it is going has me asking one question. When you notice losing abunch of coolant have you ever drained your oil imediately afterwards? The only reason this comes to mind is because you say you dont see it anywhere on the ground, and if you have a bad head gasket then the coolant will leak into the pistons and mix with the oil basically. Im not saying this is your problem, but its an idea to check the oil next time you notice a lot of coolant missing.
Thats not normal.
The cooling system is a sealed pressurized system
and coolent loss is a sign of a problem somewhere.
Any big rash of cat deaths from anti-freeze poisining
in your neighborhood over the last, lets say, 3 years?
The only time ive seen coolant on the ground are the two times i drove for about 8 miles and i watched it dump about a half gallon under the engine. As far as the cap being sealed, there is a sign on the backside of the reservoir where it looks like coolant has dripped down the side of the reservoir from the cap. I cleaned it up a little bit last night but i will take a picture on my lunch break and post it up. But other than that, i have never seen any leaks
I agree, the dealership is just going to try and play you until your out of warranty. If you actually see coolant on the ground then i would try replacing the cap first off.
