gas smell???
Over the last few months, i've noticed a raw gasoline odor inside the car. i can smell it a little outside the car but more noticeably inside. I've even had people ask me if i spilled gas on my clothes! I already checked my injectors for leakage, and replaced the o-rings to be on the safe side. i even changed the fuel filter...anyone else have this issue or know of any common problem like this on the 05+ GT's???
no, I've never had the fuel upgrade done.....why you ask? Do they usually go bad quick? Cuz I've never installed anything that would require a more powerful pump. And unfortunately, I never have gotten any EVAP M.I.L. code. The only code I've gotten before was a while ago, and it was "system too lean". Not even that has anything to do with it though, i would understand "system too rich" or something.....It's just really embarrasing and i dont want anything to progress and get really bad. Trying to avoid as many repairs as possible, ya know? lol.
There's a safe dye you can put in your tank. It shows up under a black light, and can be used to troubleshoot fuel (and oil, coolant, and A/C) leaks. I used it with good results a while back. Link.
Thanks for your inputs guys, but i cant afford the $50 to locate the leak. Than I'll have to fix it! lol. I appreciate your help tho btw. Just hoping for a quick, easy fixer-upper.
I had a gas smell a month ago. No obvious leakage anywhere, nothing wet or damp, still a horrible gas smell that would get you sick at ur stomach. Finally did a smoke test: I had the plugs changed 2 months before and the shop didn't torque the new plugs right, the #5 and 8 plugs had worked loose and it was raw combustion gases blowing past the plugs. I got lucky and had no further damage and it runs like it should now. Hope it's something simple.
bradleyb
Nov 27, 2015 07:50 PM
