Engine hiccup opinions needed
When driving along every once in while the engine feels like you un-plug a coil or something for a split second. You can drive serveral miles without a problem then it does it. I get no light but it seems as though a cyclinder just quits for a split second. If I get on it it will briefly cut out at about 6k just as it going to shift. D0 you think its a bad coil or a plug. I have the GMS X-stream cop's and Brisk plugs. I'm going to put the stock cop's back on tommorow and see what happens. When I first installed the cop's a couple weeks back everything was good, but this problem has been going on the past few days.
I had that issue a few months back it was surging and didnt throw any codes. I had the fuel filter replaced with a high flow unit was probably just dirty though and the problem went away. Not sure if it is the same thing but it is a cheap place to start looking and a good idea to change the filter out ever so often anyway.
I had the fuel filter changed a year ago this month, I have less then 10k since. They put on an after market one can't remember the brand. Which brand high flow did you use, I didn't know there was one made.
I solved the problem, I took the pos GMS coils off and replaced them with the stock ones, the car now runs perfect, 0-6k rpm's not a miss. I was in denial thinking it was everything except the cop's, I didn't want to admit to myself, I flushed 470.00 dollars down the toliet but I guess I did. I have never seen such a generic item that cost this much. The wires didn't fit right you had to stretch them to connect, the plactic parts on the metal connectors broke off. I'm going to send them back but it's a replacement only warranty, I'll try to sell the new ones on e-bay. I will never ever get sucked in buying after market coils again. I should have taken everyone's advice and left the stock one's on.
Glad you fixed the problem. I havent changed those out so I doubt those r the problem. I just bought a k&n oil filter and Fram Fuel filter I have to change the oil now anyway so I figured Ill change those out too and see if anything gets better. Also I use k&n air filter and I have been told that the oil from the filter sometimes gets on the MAF sensor and will give the engine hiccups, so I bought some MAF sensor cleaner from amazon and will be trying that too.
I have been hearing alot that since there is 10% ethonol in the gas now that the fuel filters and mesh fuel filter in the gas tank get clogged really quick now. I guess the ethonol forms some kind of thick sludge or something.
same thing
I have the same thing happening. Mine is 2005 gt oem coil packs. Just happens at idle in gear, less in neutral, and not at speed. I am going to change out the plugs, and then the coil packs. Unless someone has a better idea. I was also told that there was a problem with the original plugs and they like to break off in the cylinder head. Anyone heard of that?
