EXPERTS WANTED!!!
Old May 3, 2009 | 11:06 AM
drbobvs's Avatar
drbobvs
+1 on the UDP's, I loved them when I was N/A and definitely felt a difference when they were gone. They added 9 WHP to my car.
Old May 4, 2009 | 08:25 PM
Diabolical!'s Avatar
Diabolical!
Originally Posted by rjreyes34
Hers is a couple of questions for you experts on mustangs...
I have a 2006 Mustang GT Convertible (Automatic). My wish list on some mods is the following:
1. Dual Exhaust -> FRPP GTA's about $450
2. Mid Pipes -> Bassani x-pipes about $250
3. 4.10 Rear End Gears & Tracktion Lok about $190 (plus installation)
4. CAI Still looking for some suggestions but I figure about $280
5. Underdrive pullies -> Steeda about $190 (plus installation)
6. Throttle Body -> BBK dual 62mm about $300
7. Tuner still looking for suggestions on which one but figure about $380
My questions are...
Is this a good order?
Do my items and products look to be good decisions?
If I did these mods what do you think my HP would be... Approx?
Exhaust won't really net you any HP.
Your car came with traction lock.
A good tuned CAI will cost you much more than $280. Expect about $500.
Underdrive pullies are a decent choice if you're staying N/A.
Your stock throttle body flows fine naturally aspirated.
If you want a custom tune, you'll spend about what your expecting to, possibly more.
With a good CAI and underdrive pullies and a proper tune, you could see as much as 300rwhp. The 4.10s will really help you off the line.
For the other guy: What's this business about centris being inferior to other types of superchargers? Having worked in the performance industry for several years, I can promise you that simply isn't true. (Coming from a twin-screw owner.)
Old May 5, 2009 | 11:00 AM
slayr281's Avatar
slayr281
Originally Posted by Legion5
Lets see your total would be $2860 installed. I'm normally completely against centri superchargers because when you compare an intercooled centri to any other intercooled power adder at the same price range they make no sense both in quality and results. However you just can't argue with the non-intercooled price:
http://www.lastcallracing.com/pax-1001851-1.html
So by spending the exact same amount of money you'd have a supercharger waiting to be installed instead of a bunch of silly parts that don't do much if anything on the car.
I'll personally come to your house and beat you up if you short change yourself with expensive bolt ons instead of an entry supercharger.
I agree with you there. Average gain on an entry level supercharger is 30-35%, and 300hp flywheel, you'll now be about 400, compared to all those modifications which realistically won't put you much higher than 330 or 340hp flywheel. The other beauty of the supercharger is that when you have other supporting mods like fuel and cooling (intercooler/snow), is that you can change the pulley on the supercharger and gain even more, whereas those N/A mods will eventually top off, hitting a plateau until you get a power adder or other expensive mod like stroking, cams, or heads, all of which may still not get you to the horsepower level that the supercharger would have done on its own. If you're not installing them yourself, you'll also add some significant labor costs making your N/A build many times more expensive than that supercharger from the get-go.
I've also heard good things about Last Call Racing, give those guys a call and see what they think about your choices/situation.
Also, a centri isn't a bad blower design at all either, it's rather efficient and its power comes differently than the positive displacement blowers. Each have their unique benefits which depending on your application/desires/setup, and are still probably the best true bolt-on and bang-buck modification. Sure, they're expensive, but nothing can really gain you the power they can make, and when you compare an entry level supercharger against a big N/A build, they win every single time.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Cavedawg
Sep 17, 2015 09:51 AM
baron95
Sep 6, 2015 09:24 PM
whatsup62
Sep 3, 2015 01:38 PM
