06 GT Clunk Sounds from Rear End
Old May 11, 2009 | 01:33 PM
06Maverick's Avatar
06Maverick
Exclamation 06 GT Clunk Sounds from Rear End
Was wondering if anyone has experience this problem and has been able to have it resolved? Ive developed a clunk/chatter/jarring coming from the rear of my car. It sounds like its located in the right rear area. Ive climbed underneath the car, and checked everything to make sure its tight.
The sound is frequent when driving on bumpy roads or dips in the street. It sounds like something is loose. I have had it checked out by the dealer and they cant find anything...
Could it be the rearend itself? If so, does anyone know what type of rearends are in these cars? Is it a floating c-clip setup or a traditional setup like a FORD 9"? Is there a TSB for it?
Heres my suspension setup:
Eibach Pro Kit Coils
SVT Front Strut Mounts
SVT Front LCAs
SVT Rear LCAs
BMR Adjustable Panhard
Any info is appreciated as my dealer is really willing to work with me on this, but I cant find the cause and neither can they.... Thanks!
Old May 11, 2009 | 05:51 PM
dolint95's Avatar
dolint95
I also have a 2006 Mustang GT that does the same damn thing! At low speeds when I pull in driveways and such...there is like a clunking in the rear end, check to see if there is any play in the two bushings that the sway bar runs through. Also, take your sway bar off and see if that resolves the problem, if so, then you may need to get a new setup. I have to do the same thing, just haven't gotten around to it yet. Too worried about ordering my blower..
Old May 11, 2009 | 06:01 PM
S197steve's Avatar
S197steve
I've got the same noise myself... seems to have only reared it's head once I installed my LCAs.
I really just started noticing it the past few days and they've been on for about 2 weeks now. It almost sounds like the driveshaft...
Old May 11, 2009 | 07:09 PM
nmd55's Avatar
nmd55
yea when i changed my LCAs with welded relocation brackets i got a clunking noise. I was told it could be due to an incorrect pinion angle. So I also changed to an adjustable UCA and corrected the pinion angle. But the noise is still there.
I hear it anytime i shift gears and enage the clutch or hit a bump.
Old May 11, 2009 | 07:25 PM
doctorstrobe's Avatar
doctorstrobe
I believe it's slop in the driveline. Specifically the output of the transmission (manual).
Try this. Leave transmission in 1st, clutch out when you pull into driveway or wherever you know it makes the noise. Use brakes to slow your speed. You won't hear the noise...
With the driveshaft off you can grab the output flange of the tranny and it has a lot of slop...
I think it's always there, you just hear it more with aftermarket control arms with stiffer bushings...
Old May 11, 2009 | 07:43 PM
S197steve's Avatar
S197steve
Hmmm... that makes sense. Thanks for the info, I'll give it a whirl on the drive into work tomorrow.
Old May 11, 2009 | 10:47 PM
desslok40's Avatar
desslok40
There are a couple of things, I have been down this road. First there is some slop in the axles so you can get a slight clunk when slowing and reving back up. Primarily the clunking comes from aftermarket control arms, most have regular size bolt openings, while the Ford acceptor brackets are for millimeters, so there is just enough of a gap to cause clunking under heavy load, problem persists even at high speed just not as noticeable, so you can do a few things. Use washers to secure the bolts to the brackets, get relocation brackets (BMR, etc...) so that way the bolts fit tight, or just live with it. I have gone with the later, someday I will swap out the stock upper and lower contral arm brackets and that should do the trick but they are expensive for what they are, the real fault lies with vendors as they should have made the fitment perfect, obviously they didn't test or didn't spec out the part dimensions for the vehicle.
Adding any aftermarket suspension parts will usually generate more noise than stock so you have to figure out what's more important, this isn't a cadillac !!! lol
Old May 12, 2009 | 12:13 PM
nmd55's Avatar
nmd55
would an aluminum drive shaft reduce the noise?
Old May 12, 2009 | 12:46 PM
Riptide's Avatar
Riptide
My 06 does this as well. Clunking or a chuckle sound coming from the rear end like something is loose back there. Only does it under certain conditions. Washboard pavement on the road or pulling into my driveway. If I have a bit of speed getting into the driveway it tends to not do it as much. But it almost always does.
Mine has always done it, even before installing the Steeda LCA.
Old May 12, 2009 | 05:30 PM
06stangGT's Avatar
06stangGT
my 06 does this as well! have brought it to the dealer several times and they can't find anything. Only suspension mod i have is the pro-kit. and this noise was there before i installed this. everybody else that has posted so far is dead on, certain conditions, low speeds, pulling into driveway. what to do!?
