Bucks in 1st gear when cold?
Anyone ever had this happen. I start my car, it bucks when in 1st gear. RPM's don't go nutty or anything, just bucks, then after the motor heats up, no bucking? I just had the car retuned at Brenspeed and they adjusted my throttle to make it less sensitive. But, it's fine after I drive it 5 or 10 minutes, so I don't think its the tune.
Any thoughts?
Thanks
Any thoughts?
Thanks
You are in open loop mode and the brenspeed tune has little effect
during that mode until the PCM enters closed loop when it starts
using the brenspeed tune parameters....
Let the cats warm up and its closed loop mode for you real soon.
mines does it too with the brenspeed tune.actually mines only does it cold and when i reach a 1000 rpms only, but when it warms up it goes away.i spoke to them about it and they told me to clean the throttle body.my bama race tune used to do it even worth.
yeah not to keep saying the same thing but mine did it until I cleaned the throttle body out. I was surprised at how much build up there was in there. Now when I start it just give it a few seconds in the summer, a little longer in the winter and no problems.
