Hot Rod cams+ lockouts??
Old Aug 15, 2009 | 04:39 PM
91GTSTANGKID's Avatar
91GTSTANGKID
Default Hot Rod cams+ lockouts??
okay so i jut bought a set of FRPP Hot Rod cams for my 05 mustang Gt. I have bad cam phasers that knock/tick and i was wondering if i could use lockouts with these cams? will it hurt my power gains or anything??
Old Aug 15, 2009 | 06:22 PM
SirKnightTG's Avatar
SirKnightTG
Phaser limiters will stop any ticking plus allow you to keep the benefits of the VCT. See the Comp Cams article about them.
hammeron's Avatar
hammeron
certainly you can use lockouts, if that's what
you want to do. i can't tell you how much power
you will lose because i don't know if you are going
to install them full advance or full retard.
me personally, i would replace the phasers while doing
the cam install, then you would have a working VCT
system.
Old Aug 15, 2009 | 06:30 PM
SirKnightTG
BTW, Brenspeed sells new phasers.
Old Aug 15, 2009 | 09:20 PM
91GTSTANGKID
well should i get limiters or lockouts?? or should i buy a whole new phasers??
Old Aug 15, 2009 | 10:18 PM
hammeron's Avatar
hammeron
i would go with new phasers
Old Aug 15, 2009 | 10:23 PM
SirKnightTG
Probably new phasers would be best.
But if you were getting a cam that needed either limiters or lockouts, like most cams by Comp, then I'd say limiters. Lockouts would throw you back many years in the past and you lose what VCT gives you. But the Hot Rod cams don't need either so you're good with just new phasers.
Old Aug 15, 2009 | 10:53 PM
91GTSTANGKID
alright good to know i just want to get rid of that ticking/knocking nosie and i figured since im changing cams id fix the noise i just hope these ones dont go bad and start ticking.
Old Aug 16, 2009 | 12:31 AM
Skarkull's Avatar
Skarkull
Originally Posted by hammeron
I can't tell you how much power
"Everybody knows you never do a full retard...Sean Penn in ‘I Am Sam.’ He went full retard. Left the Oscars empty-handed. You went full retard, man. Never go full retard. "
Old Aug 16, 2009 | 11:48 AM
hammeron's Avatar
hammeron
bradleyb
Nov 27, 2015 07:50 PM
jrrhd73must
Oct 2, 2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
UrS4
Sep 30, 2015 10:13 AM
