More Power!
how about this:
http://www.brenspeed.com/720.html
and this:
http://www.brenspeed.com/dshaft05gt.html
and this:
http://www.brenspeed.com/m-9926-3v.html
and this:
and this:
I need some help. My wife wants more power for her 2010 GT. I know the basic options: 1) S/C or turbos, 2) cams/heads/other or wait for the 2011's. I got 1 and 3 figured out, but what about #2? Is there anything I can do for a couple grand and get a 100 HP in return? No nitrous. Thanks.
swapping to 4.10 or 4.30 gears for about $500 will give the car a simulated +30 RWHP.
add in a good CAI & tuning & better mufflers for another $600-750
those 2 combined will make the car a whole new beast.
after that, time for a blower
Sorry dont mean to jack this thread but was wondering if the motion delete plates are worth the money? How much HP and TQ and whats the benefits sorry if this is a newb question Im a New Edge guy and new to the S197! Thanks!
Motion delete plates IMO are a waste of money. Too little hp gained for the amount of money that they run.
The Whipple intake does not have charge motion plates, so it's kind of like a "free charge motion plate delete kit"!!!!!!!!!
Thanks everyone! This was posted on a different forum and I thought it might be of interest:
Some of this has already been said, but I thought I’d chime in with a little more input for bolt-ons sense your new to the s197 world ( 4.6L 3V ) Keep in mind I’m not some car mechanic that has graduated and has certificates in any of these fields… I’m 20 years old and passing on information that I’ve learned and/or heard from the past 3 years of owning my car. And trust me… I’m on the forums A-LOT.
Headers: If you are staying NA these a good mod, but aren’t the best bang for the buck. They’re pretty pricey and are a PITA for install. Average gains are from 15-25hp at the crank from the various brands. If you are going to supercharged your car these aren’t a good buy UNLESS you are going with a forged short block. Out of the box most superchargers will put out enough horsepower to bring the block to its limits, with or without headers.
Mufflers & Midpipe: the gains with these two are so small it, Power shouldn’t be on the buyers priority list at all, The stock exhaust is good for more than the stock block can handle. That being said, you can buy them for sound, and turn that 4.6L 3v into a bad sounding beast.
Gears: At 400-500$ Installed, this has got to be one of my favorite mods i have done personally. Gears should only be installed if you already know the goals of your stang. Picking the right gear for the Supercharger, Turbo, Nos, or even staying NA can make all the difference in your 1/4 mile time, and keeping that power to the ground. For example, I have 4.10's in my car, and I’m planning on going with a twinscrew for instant toque. I will be spinning tires a little too much because of my gears being so tall and my car will have 400rwtq right off the line. 3.73's seem to be the favorite for FI applications and for NA 4.10 or 4.30's but make sure you go with FRPP gears, they don’t have as many horror stories about gear whine.
CAI+Tune: CAI+Tune have been voted by S197 owners as best bang for the buck in almost every forum dedicated to them. That being said, your car comes with a decent one already from the factory but can still get a lot of improvement from the tune. Bamachips, Brenspeed, VMP tuning, there all good, if you can afford it, a dyno tune would be even better, but Mail orders are good for the price. Something to consider, you will need to retune your car again and again and again, if you keep doing mods one at a time, So I try to do everything together, as much as possible.
UDP & CMDP: "Underdrive Pulleys & Charge Motion Delete Plates" can be good for 10-20 hp at the crank. Usually not really worth it... but again if you’re staying NA, every little bit helps.
LCA + UCA: Lower Control Arms and Upper Control Arms, are a great investment to keep the back end of the car planted, and actually use the power, instead of having wheel hop or spinning tires as much. These both can be had and installed for around 400 dollars and should be done to the suspension at a bare minimum.
Handling: To further go into our suspension, if handling is something your interested in, a great way to improve that is a box set of parts, For example, FRPP, Steeda, Saleen, and many others, all make box sets which include Stocks, Struts, Sway bars, Strut tower brace, and springs. These parts are all made to work together are going to yield a better result most of the time then buying single pieces from different brands.
For someone on a budget, new Shocks & Struts & Swaybars, are best bang for the buck in handling. Everyone thinks if you lower the car on the stock shocks and struts, the car will magically handle better because it’s slammed to the ground... (While I was a believer in this too when I first bought the car) that’s not the case at all. Shocks and Struts are the weak part in our cars, after the LCA & UCA.
Has anyone dyno'd their car before/after making changes to their cams, exhaust, headers, etc. (number 2 at the top). Been wondering. Wife said no to trading for a 2011, probably going to go with piecemeal enhancements. Supercharger also out (for now). Sorry for resurrecting an old thread.
On an automatic I suggest adding 4.10 or 4.30 (Better) gears and a good converter as supporting mods. Otherwise the car is going to be weaker off the bottom.
