Clutch/Slave cylinder replacement
Hey guys so my clutch went awhile back. I have ordered a clutch and flywheel. In regards to replacing the clutch, how much more work is it to replace the slave cylinder. Ive been told when doing the clutch you should do the slave cyl as well. I just wasnt sure how much more work this is or is it neccessary?
your car is a 05, if you have the OEM slave, swap it while you in there, easy to do since the tranny is already out, use a OEM/OEM replacement unit. if you want JPC has a upgrade kit for the 07+ model years retro fit to the 05-06s
AmericanMuscle4.6GT
11-10-2015 02:06 PM
