Help! 98GT problems
Old May 15, 2010 | 09:39 PM
Robs98GT's Avatar
Robs98GT
Default Help! 98GT problems
So today I was driving along about 50mph and the car just died in the middle of the road. No check engine light. No weird noises. Car will not start back. Checked diagnostics with diablo and nothing shows up. Installed factory tune but same result. It sounds like it tries to start but it's almost like it has no fuel. And yes there is gas in the tank. Also noticed when I turn the key on without starting it I can't hear the fuel pump build pressure. If anyone has seen this before or has advice on where to start I would appreciate it.
Old May 16, 2010 | 07:44 AM
BigDinTexas's Avatar
BigDinTexas
Sounds like you are looking in the right direction... Is you fuel filter clogged? Is the pump actually pumping? What about spark? Do you know if you are getting a good spark? Has your vehicle been running rough lately or is this all of a sudden?
Don
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
