help is this normal????
Old May 14, 2010 | 04:09 PM
M7MDGOTHICA's Avatar
M7MDGOTHICA
Default help is this normal????
yesterday i drove my car and it didnt had fuel and i had to drive on an empty tank for few minutes, today i started the car and i didnt notice anythin diffrent untill few minutes later the car was driving weird i mean when i hit the gas it was heavy and felt diifrent than i noticed a yellow light that turned in the speed meter, i turned the car off than on again it was ok
what do you guys think is this related or is ther a problem ?
i have less than 4000 miles on it
Old May 14, 2010 | 06:59 PM
cidsamuth's Avatar
cidsamuth
Your description isn't good. Based on what you wrote, I recommend unplugging the negative terminal on the batter for 30 minutes. This will reset the computer. When you start it back up, let it idle to operating temperature, then turn on the A/C for a couple of minutes. This will set the idle.
Then drive it for 10+ miles to set the "adaptive behavior."
Old May 15, 2010 | 03:15 PM
M7MDGOTHICA
today it happend again and than when i switched off and on the car it was fine, and than few hours later it happend again
i checked the manual and indicator that comes on its the electronic throtle lag response the yellow wrench light
what does it mean? is it not good?
is it safe to drive it or will i be damaging the car more
Old May 15, 2010 | 05:16 PM
M7MDGOTHICA
anyone?????
Old May 15, 2010 | 08:28 PM
ShaneM's Avatar
ShaneM
You need to take it in and have the deasler pull error codes, or with it being the weeken dgo to yourt local autozone, they will do it for free. Don't reset the comptuer before you go or they won't be able to see what it is doing. It's a new car no sense in you owrrying about it, take it in that's what the warranty is for. I beleive that yellow wrench light is fail safe mode even with all the errors my car was throwing from a faulty trans sensor that never came on. Take it in. I'm wondienrg if it didn't pull some gunk into a line somewhere when your tank went near dry. Was your FG red? it gets red when you are really, realyl low on fuel.
OT- I was out the other night driving somewhere, not normally out at night and was messing around and took the car to redline and noticed the tach turns red for a second when you hit redline. it was cool, had me wishing you could set that to turn red a few hundred RPM before redline, would make a great baked in shift light. It was very bright with all other lights inside the car on blue.
Old May 15, 2010 | 08:42 PM
Diabolical!'s Avatar
Diabolical!
Whenever you run the tank down to empty, you risk sucking trash into the fuel line (even the most trustworthy fuel stations have some trash in their gas). Get your error codes checksd (most auto parts stores will do it for free or very cheap) and address the codes. My first step would be to replace the in-line fuel filter. It may be plugged with gunk.
Old May 16, 2010 | 09:47 AM
M7MDGOTHICA
whats FG? and nothing turned red
well today the wrench light so far is gone but something happend today well i went full throttle from start and while i was goin full speed i think one of the gears didnt shift and i let go the gas and was fine i did it again and was fine.
the car is alrght now but i am taking it probably tommorow to get it checked.
you guys hink i damaged anything in the car
Old May 16, 2010 | 01:25 PM
Nuke's Avatar
Nuke
FG = Fuel Gauge
I'm having difficulty understanding what it is you're describing. It seems that, whatever the problem is, it resets when you turn off the ignition and then re-start. But please let us know what they say at the shop.
Old May 16, 2010 | 03:18 PM
M7MDGOTHICA
well the car now seems to be alright but i noticed the oil pressure meter is going more toward the H, tomorow am taking it to the dealership
hope i didnt damage my car
Old May 16, 2010 | 03:19 PM
M7MDGOTHICA
well the car seems to be working ok but i noticed that the oil pressure meter is goin more towards the H
tomorow am taking it to the dealership, i hope i didnt damage my car
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
