engine build questions
Old Jun 11, 2010 | 02:41 PM
graygt07's Avatar
graygt07
Default engine build questions
i have 07 gt auto with saleen supershaker and 12# boost. i am getting the aluminator with the 9.5 comp. i know alot of people say get the 8.7 comp for supercharger. saleen has one pulley smaller then the one i have and with a 10% overdrive crank pulley i will only see 15 to 16# boost. i will be getting a mild cam and a larger heat exchanger. i think i will see around 525rwhp. is anyone running a higher comp. a supercharger and 93 octane? will i be ok running this set up on 93? anyone running over 500rwhp and 39# injectors?
Old Jun 11, 2010 | 05:47 PM
BruceH's Avatar
BruceH
I'm running a 9.5:1 motor with a Whipple and 92 octane. My last dyno pull showed about 13.6 psi and 517rwhp. Since then I've added a 10% overdrive balancer and larger sc pulley. Haven't had it on the dyno but did see 15 psi during a brief wot 3rd gear pull.
My car maxed out 488 with 38lb. injectors and the stock maf. I'd think you might want to just upgrade to 60's now instead of later and save tuning costs.
Old Jun 12, 2010 | 12:00 PM
Simon1's Avatar
Simon1
Should be fine on the motor.
60# injectors for sure.
New MAF or a MAFia.
Old Jun 14, 2010 | 01:50 PM
AmericanSpeed's Avatar
AmericanSpeed
9.5:1 compression or 9.8:1 compression? I don't see any listing for an Aluminator with 9.5:1, I only see the 9.8:1 or the 8.7:1 for the 3Vs on FRPP's site?
Old Jun 14, 2010 | 05:09 PM
graygt07's Avatar
graygt07
sorry typo i meant 9.8
Old Aug 20, 2010 | 08:53 PM
dolint95's Avatar
dolint95
39# injectors 519rwhp
Old Aug 21, 2010 | 02:40 AM
stealth_GT's Avatar
stealth_GT
Kinda off topic, but how does the auto run with the Supershaker and whats your gear ratio??
Always been interested in how that combo would feel like..
Old Aug 21, 2010 | 09:07 AM
BruceH's Avatar
BruceH
Here's the dyno sheet from when mine maxed out. You can see the af line dip rich and then start lean, that comes from the injectors running full duty cycle. My tuner also said he didn't feel comfortable compressing the maf anymore at that point and that I needed bigger injectors and a different maf to push more boost.
Same motor with GT500 injectors and a pmas hpx maf, more boost, and a frpp tb.
Old Aug 21, 2010 | 06:06 PM
SpartaPerformance's Avatar
SpartaPerformance
Yes the 9.8:1 compression would be an excellent choice, stick with it.
Old Aug 22, 2010 | 02:43 PM
graygt07's Avatar
graygt07
love the supershaker with an auto. runs like a champ. stock gears 3.31. I swapped out the block with JDM's forged 302 with 9.8 cr. 260 miles do far and doing good
