Issues with going into reverse
Old Jun 24, 2010 | 09:07 AM
sweetlou69's Avatar
sweetlou69
Default Issues with going into reverse
So last year i had my rear end replaced and about 2 months ago i replaced the clutch/flywheel in my 05 GT. Past week or so ive noticed that sometimes im having difficulties going into reverse. Sometimes it takes 3-4 tries to jam it into reverse, to the point where it almost doest budge. Also sometimes hitting 2nd gear isnt always the easiest. By the way i also have a triax in there.. Any ideas? syncros maybe?
Old Jun 24, 2010 | 02:54 PM
Stkjock's Avatar
Stkjock
Retired Mod
check the bolts on the shifter under the car
did you replace the slave when you did the clutch?
Old Jun 24, 2010 | 05:32 PM
BruceH's Avatar
BruceH
Is it getting hard to get into first with the motor running? Could be the slave like mentioned above.
Old Jun 24, 2010 | 09:32 PM
Lax07's Avatar
Lax07
I had a similar issue that got so bad I couldn't get it into gear unless the car was moving or turned off... turned out it was the master and slave cylinder and the throw out bearing shot apart when they opened the transmission... all under warranty for me though..
Old Jun 24, 2010 | 09:41 PM
BruceH's Avatar
BruceH
I really hope you didn't put a Centerforce in.
Old Jun 25, 2010 | 12:33 AM
loots06's Avatar
loots06
Originally Posted by Stkjock
check the bolts on the shifter.
Check out my thread..I had the same issue turned out to be a simple solution.
http://www.s197forum.com/forum/showthread.php?t=36543
If you have a two piece unit shifter then check the top bolt.....If you need a slave I have one sitting in my garage...
Old Jun 25, 2010 | 09:07 AM
sweetlou69's Avatar
sweetlou69
no centerforce, was replaced with a Spec stage 2.
I did repalce the slave cylinder, but not the master. First gear and all other gears pop in with ease. Just seems to be 2nd and reverse at times.
Loots thanks for the thread,ill check that out
Old Jun 25, 2010 | 04:22 PM
157dB's Avatar
157dB
Cut & Paste Expert
tHE REVERSE PROBLEM IS NORMAL.
iTS MANDATORY TO DO A 4TH first then REV TO ACTIVATE THE REV
LOCK-OUT FEATURE...
Fricken caps loock
Old Jun 25, 2010 | 08:17 PM
red96v6's Avatar
red96v6
Never worked on the tranny in my 07, but it doesnt like 2nd or reverse, either. And of course the stealership could never recreate the problem...
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
