Floor Jack
Old Jul 9, 2010 | 10:54 AM
rhood's Avatar
rhood
Default Floor Jack
Hi
Going to replace my mufflers today so Where is the right place to place the floor jack to lift the rear ?
Thanks
Old Jul 9, 2010 | 11:58 AM
Riptide's Avatar
Riptide
This is more of a general tech question and should be put there.
Whatever you do don't lift the rear up by the differential. If you do God will kill a small kitten.
And if God doesn't 157db is going to spear the poor little fellow.
Old Jul 9, 2010 | 12:01 PM
Nuke's Avatar
Nuke
Unless you're lowered you can simply back up to a curb or a drop (like from the driveway to the street) in order to get what little clearance you need to swap axlebacks. Of course, a good set of ramps (like the RhinoRamps that I have) work like a charm.
Old Jul 9, 2010 | 01:25 PM
hammeron's Avatar
hammeron
exactly. with stock rear springs i was able to just lay on the floor in my garage and change them.
Old Jul 9, 2010 | 01:46 PM
shanec's Avatar
shanec
Same here. Before installing a lowering kit, I changed my muffs several times just by laying on the floor.
Old Jul 9, 2010 | 02:47 PM
stealth_GT's Avatar
stealth_GT
no pumpkin jackers here? lol
Old Jul 9, 2010 | 08:57 PM
jwth2005's Avatar
jwth2005
How much were those ramps and whered u get em
Old Jul 9, 2010 | 09:21 PM
atomicpunk's Avatar
atomicpunk
Got mine at Pep Boys for around $35 on sale, they have them at Autozone also.
I'm also a pumpkin jacker for the record.
I'm lowered now and have a CDC Classic chin and had to make ramps to drive onto the ramps for the front.
Old Jul 9, 2010 | 11:14 PM
tx_zstang's Avatar
tx_zstang
Ghetto ramps: 2 4x6 blocks of wood, drive up on them and you're plenty high, especially with stock height.
Back partway out of the garage if you have one, and you'll probably have enough room.
No need to jack the car up for most people.
Old Jul 10, 2010 | 01:28 AM
Diabolical!'s Avatar
Diabolical!
Jack it up using a block of wood under the pumpkin...
yeah, that's right, the PUMPKIN.
