2007 mustang gt camshaft phaser problems!!!! PLEASE HELP
Old May 20, 2011 | 09:24 AM
adj86's Avatar
adj86
Originally Posted by KingCobra78
Good Day
(2006 Mustang GT - Code P0340 - camshaft position sensor A - Bank 1 circuit)
I replaced the cam sensor and code returned. I see the note above about cleaning/replacing the filter in the oil control housing. Has anyone had any luck with this and can you tell me where this filter is? Would you suggest "cleaning" the engine with SeaFoam etc? Thanks In Advance... 1SG(R) M
There is a strong to very strong chance your alternator is going bad. I've replaced mine twice and am on my 3rd one. Has the alt ever been replaced on your car? Each one of my FOMOCO alts lasted about 3 years. I bought a PA Performance Alt since they are not rebuilt and have a life time warranty, as long as you buy the power cable from them. It's possible its not your alternator. You can test it to see if its the alt. Start your car up and then disconnect the ground cable that's connected to the battery. If the car dies at disconnect then its the alt.
Check out this forum topic
https://mustangforums.com/forum/gt-s...t-to-do-2.html
Old May 22, 2011 | 06:25 AM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
I had the same code thrown at me when my alternator went bad in my 06GT
Ford has replaced the alternators on these with FOUR different models so far.
Old Jul 19, 2011 | 10:26 AM
aalex6104's Avatar
aalex6104
Default Same problem here for the last 3 months !
My Gt 2008 , is driving me crazy all i want is to set it on fire, i already replace the vct selinoids, the cam phasers, the oil pump and new cramshaft,
after it warms up the car goes from perfect to real bad , RPM's don't hold and it just goes from 300 to 1200 like crazy, it is bad and i have it on my own shop for the last 3 months,
Any Help ???
Old Oct 27, 2011 | 01:58 PM
AE05gt's Avatar
AE05gt
I as well have the same code as KingCobra78.
my problem is i hear a whining and when the cruise is on it it rev's up realy fast then drops it last about a sec long
its a 05 gt
Old Oct 27, 2011 | 02:06 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Any Help ???
Same code as the other cars in this thread?
RPM's all over the place could be IAC valve or even the throttle body itself. During warm up a car ignores all sensor input and runs on default settings so if this is happening after the car warms up, it's most likley a sensor problem.
Old Jun 17, 2012 | 05:07 PM
300angryhorses's Avatar
300angryhorses
I have been dealing with the same problem & code (oops, forgot to put p0022) for the last three weeks. I replaced the solenoids and recently the oil pump. Before replacing the pump, my pressure at idle was less than 10 psi, and I was only at 50 psi at 2000 rpms. With the new pump the idle pressure is between 25-30 psi, but the problem is still there.
As soon as the engine temp get above 105 degrees or so, the idle goes crazy, dropping to 500 or less and then reving to 1200 or so. I seems to straighten out when i give it gas and get it to higher rpms, but then when I let it idle back down, it starts acting up again.
Last edited by 300angryhorses; Jun 18, 2012 at 08:25 PM. Reason: added the code p0022
Old Jun 18, 2012 | 05:09 PM
Simon1's Avatar
Simon1
YOu need to get your battery and alternator checked. Or just replace the alternator. P0340 means you need an alternator.
Old Jun 18, 2012 | 08:24 PM
300angryhorses
sorry. I should have been clearer. I have the P0022 code mentioned in the original post.
My battery is just a few months old. My alternator did pass the 'disconnect the negative while it's running' test. I did pull it off and took it to Autozone and O'Reilly's to get it tested, just because of some of the posts that I've read on a new alternator solving p0022 problems. But both places said that they couldn't hook it up to the machine because of the u-shaped mounts?
Old Jan 2, 2020 | 09:41 PM
Stang061993's Avatar
Stang061993
Default ???
Originally Posted by chrisgtpony
So for the past 14 weeks i have had nothing but problems with my mustang. I have had a shortblock, a new PCM, New cam phasers solenoids and valve bodies, new oil pump, and even swapped from a diablo tune to an sct tune per fords request. I have spent over $3,000 of my own money on some parts and labor and am ready to pull my hair out. I have taken care of all the problems that my car had but the P0022 code which is Camshaft position over retarded bank 2 still remains. When this occurs though i get a misfire on cylinder 5 and a wicked valve knock. So my question is how or what do i need to do to correct this over retardation. Ford is out of ideas and will no longer look at it.
I have thought about the Phaser limiters but i dont think i should have to go that route. about the only option that i have left is trade the car in but i dont want to totally start over on another one. I have put to much time and money into this to just walk away from it. Any and all help or advice or ideas will be greatly appreciated
did u ever find out what it was or you got rid of the car before fixing it ?
Old Jan 3, 2020 | 04:10 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Holy necroposting!
Ten years on he's either sold the car, burnt it to the ground, or pushed it over a cliff. If, by some miracle, he fixed the problem and still owns the car, you might actually get a response.
