Short Throw Shifters. HONESTY folks!
O.K. I have been thinking and I am really considering a short throw shifter as my next mod. I am going to have to save up for it but I was considering it over a new UDP or LCA's.
Reason being is I went up against a friends mustang who only had 4.10s, CAI and canned tune, and LCA's and a Short shifter and I was really surprised at how close he kept up with me. Oh yeah... he did have a nice set of drag radials on though..
Anyhow I noticed when we were racing how much much faster he was able to shift because he had his windows rolled down and I could actually see his arm shift.
He told me how much more smoother his shifting was over stock too.
So I wanted to ask those who have them are they REALLY worth it?
Do they make shifting much more fun and feel much better?
Do they actually make the shift distance shorter?
Are there ANY possible down sides to installing one?
Also ... what is the best brand to buy?
I can't install it myself. I repeat I CANNOT do it.
I have back problems and it just wont let me do such things.
So I was wondering if any of you had a shop install one and how much they usually cost to install.
That way I can get a good idea of how much I am going to have to save up total.
I do want the best shifter available.
Thanks for the input folks!
What ever shifter you decide to get, also get a CHE K-member brace w/tq limiters. This will keep your engine and tranny inline which will virtually eliminate miss shifts. Cost for install for both shifter and CHE probably be around $150 to $200.
I am happy with my hurst with the k-member brace.
Yes, they can be remarkably shorter then stock. I have a Pro 5.0 short throw. Plus shifts are much more solid, you KNOW when you're in gear and which one. I ended up installing it myself but had a local shop quote me $100 to install.
Far as fun, yes I think they are more fun to shift with one. It's not as easy as stock though I will tell you that. Takes more muscle and effort to shift but once you got it down, you can row thru the gears a lot quicker.
I swapped out my stock shifter back in 2005 to the B&M ripper shifter and it served me well until this year. It just wore out after time and I decided to get the MGW shifter and I love it. I set it per MGW's recommendations at 5 turns out and the throw is a bit shorter than the B&M and and quite a bit shorter than the stock shifter.
I've had a hurst and mgw, recommend the mgw. It will make shifts shorter but I think it's hard to beat the stock shifter for smoothness.
If I were the OP I'd get the control arms first.
