Help Choosing Springs
Old Dec 14, 2010 | 09:59 AM
VetteHunter's Avatar
VetteHunter
Default Help Choosing Springs
I'm working on my suspension right now. So far I've got the Eibach sway kit and Steeda's adjustable LCAs. I also bought the Eibach camber bolt for when the time is right! Now I'm trying to decide on the right springs... I've heard good things about Steeda's, and I know Eibach's pro kit is the FRPP springs, and also UPR's.
Now what I'm going for is corner cutting capability. I don't plan on drag racing; and this isnt a daily driver, so comfort doesn't matter. I know I don't want to go 2" drop because I would still like to be able to drive it around town every now and then, I just don't care if I need a chiropractor! LOL
Any help would be greatly appreciated!!! Thank you all!
Old Dec 14, 2010 | 04:13 PM
SteedaGus's Avatar
SteedaGus
Former Sponsor
How much of a budget you have to work with? If you have disposable income I would be suggesting a lot more than our 555-8241 street/comp springs, Tokico D-specs, and swaybars. Which would be the basics to start with.
If you have a budget beyond these items I would also suggest our 555-8120 upper strut mounts, front ball joints to improve the front roll center, bump steer kit to correct bump steer, plus a watts links and rear trailing arms. But the parts I first mentioned would be a good starting point for aggressive handling.
You should also consider wider wheels and tires if you want to maximize grip.
Old Dec 15, 2010 | 02:21 PM
VetteHunter
i already have a set of your adjustable rear control arms, I wasn't going to go all out due to money reasons. I think im going to go with the Steeda sport springs and pro action shocks and struts. Then move on to the adjustable upper control arm, and adjustable pan hard. Then i think ill be done until the mod bug bites me again
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
