"Engine Failsafe" issues!
Old Jan 12, 2011 | 09:15 PM
DjSwayde92's Avatar
DjSwayde92
Default "Engine Failsafe" issues!
Hi I am new to the forum but my 2005 Mustang GT has recently started randomly going into its Engine Fail-Safe/ Limp home mode. It did it twice and I was close to home both times so I just 'limped home'. I then quit driving it and haven't visited the shop yet for fear of a expensive repair. Anyone having this problem? Ideas? Thank you in advance!!
Old Jan 12, 2011 | 09:22 PM
DjSwayde92's Avatar
DjSwayde92
It says in the manual that it does this when it runs hot but it has not registered hot or even a notch above normal. Again thanks for any help.
Old Jan 12, 2011 | 11:14 PM
siggyfreud's Avatar
siggyfreud
Have you tried renting the tool to pull the engine codes and see what it's saying? Autozone rents it for free I believe.
Old Jan 13, 2011 | 05:39 AM
DjSwayde92's Avatar
DjSwayde92
I actually own one but I havent tried it because I thought it only works if the check engine light is on?
Old Jan 13, 2011 | 07:17 AM
Nuke's Avatar
Nuke
No CEL? Hmmmm.... Can you tell us more about this car? Are you the original owner? Any mods? Mileage? Any other "symptoms"? History?
Old Jan 13, 2011 | 11:10 AM
DjSwayde92's Avatar
DjSwayde92
2nd owner. Only mod is the axle back muffler delete exhaust with resonaters only. About 44,000 miles. As for symptoms, The second time it went into this mode I was on the interstate and I slowed down and got off at the next exit (1.5 mi) and as I was coming down the exit the engine shut off. It started right back up and I let it rest in a parking lot for about 2 hours and then drove it home and it acted fine.
Old Jan 13, 2011 | 11:12 AM
DjSwayde92's Avatar
DjSwayde92
Also the gas pedal has been sometimes kinda unresponsive or slow to respond... I was told this was most likely the Throttle Position Sensor. And it would last "as long as i'd deal with it"
Old Jan 15, 2011 | 01:22 AM
GTRaider's Avatar
GTRaider
I had this happen to me twice in one day. Both times I hit the "reset" button on the trip computer and it cleared the Fail-Safe Mode. I had just installed a Bama tune a few days before so I called them to ask WTF they did to my car. The response was that it sometimes happens with a new tune. It never did happen again after that.
As for your issue, it still might be worth checking with a Scan Tool to see if anything pops up. There are a lot of transient things that can happen but not set a CEL.
I still say, "When unusual electrical things happen, start by cleaning the ground point attachments."
Old Jan 15, 2011 | 02:17 PM
DjSwayde92's Avatar
DjSwayde92
Thanks GTRaider! But to ask what is probably a stupid question... what/where are the ground point attachments?
Old Jan 15, 2011 | 08:25 PM
tx_zstang's Avatar
tx_zstang
Check the throttle body and sensors. You probably have a problem there.
But, do check for codes; even if the engine light is not on, there can be "Pending" codes that can help.
For a manual tranny car, things that can cause failsafe are throttle body (and its sensors/connectors), crankshaft position sensor, and a few others. For automatics, custom tunes can trigger similar issues with improper torque tables.
