whats next
whats next
just got my BBK cai and im wondering what should be my next steps to the bolt-ons.....i know i need a tuner(its a given)....right now the car has
-bbk cai
-spin tech cat backs
-short throw(not sure brand)
-1"springs(not sure brand)
um that seems just about it
tuner comin soon...thinkin pipes or headers next
any advice???
thanks!
-bbk cai
any advice???
thanks!
Are you planning go or show mods?
If it's some additional power, then probably gears, UDPs, aluminum DS...
LT's would be ok but if you can swing it, do LT's with cams. That combo works well together like a CAI & tune.
ordered the tuner...
but my only problem with cams is that i plann on doin forced induction sum time in the future....leanin more towards the S/C side....so my problem is i dont wanna get cams now and have to replace them later on...i want to find a set that i can get now an still work just as well after wards
Many NA cams will still work fine with a supercharger.
They wont give you QUITE as much power as blower cams will but they give you
to opportunity to enjoy NICE power gains now before you go F.I.
If you do not plan to go F.I. for a good while, my advice would be
gears. Then I would do long tubes so that either your super charger, or cams both get the max benefit they can.
Either way.... supercharger then cams later.... or cams then supercharger later, will BOTH benefit from those nice breathing long tubes.
Dont worry yourself too much about getting blower cams or not.
If you want the cams first for some reason GO FOR IT!
You will be fine with a normal set of cams either way.
Both the Hot Rod Cams and the Detroit Rockers will work with a supercharger.
Even if the Rocker cams are not the blower version.
