Startup technical question
Old Jan 29, 2011 | 04:19 PM
Bigorangek9's Avatar
Bigorangek9
Default Startup technical question
Got what might be a silly question. I have an 07 GT, it has a K&N cai, Bassani X pipe & mufflers, & long tube headers. When I first start the car when cold it sounds very loud & awsome! Within a minute, it slowly quiets down, even though rpm's remain unchanged. I'm sure it's something computer controlled but it makes no sense, the exhaust is open, why the sound change???
Old Jan 29, 2011 | 04:42 PM
mapitts's Avatar
mapitts
It is the Idle Air Control ( IAC ) valve. It is allowing the engine to run when it is cold for emission control. It replaced the choke on carbed engines. Mine does it as well. The throttle body plates are closed on start up. The IAC valve opens to allow combustion air in, but at a reduced rate. This is causes a slightly lower vacuum which is the cause of your sound. When the IAC closes, it increases your vacuum and your exhaust tone changes again. That may be completly wrong, but, that is how it was explained to me. If I am wrong, someone PLEASE correct me so I do not sound like a fool again.
Old Jan 29, 2011 | 06:20 PM
daredevil95's Avatar
daredevil95
Sounds good....I call it "open loop" until the car warms up.
Old Jan 29, 2011 | 07:13 PM
Nuke's Avatar
Nuke
All the S197's do it. My FRPP Stingers sound absolutely awesome on startup and then tone down a good bit.
Old Jan 29, 2011 | 07:26 PM
Bigorangek9
Ok, I figured it was computer, emissions, etc. It sounds great all the time, but for that first minute or so it's awsome. Thanks for the help.
Old Jan 30, 2011 | 07:25 AM
mapitts's Avatar
mapitts
I am not sure, but I think that it does not reach closed loop (thanks for reminding me of the proper term daredevil95) until the engine reaches normal operating temperature. BTW, you should hear my Bronco when I first crank it up!! WOW
4cylinderplus2
Oct 9, 2020 07:45 PM
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
