Check Engine Light
Old Apr 30, 2011 | 03:26 PM
Langor's Avatar
Langor
Default Check Engine Light
Hello all,
Today when I was driving my check engine light came on. I drove back to my house and checked the code with my Diablosport tuner. The codes are as follows:
P0340 "Camshaft posiion sensor a circuit"
P1000 "OBD systems readiness test not complete"
The car is running fine and is not misfireing. This happened shortly after I got on it. After I came back to my house I reset the code and started the stang. It did not trigger it again and it started fine. I did not drive it though. I wanted some input on this. Any suggestions to what may have caused this trigger? Is it safe to drive or should I take it into a shop? I am not a mechanic but I am mechanicly inclined. I looked for this sensor and I could not find it. I assumed it would be by the harmanic balancer (or whatever it is called by the pullys). Any help on this situation would be appreciated. Thank you.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
