New Intake...?
Old Oct 3, 2011 | 06:09 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
BTW really as far as performance the CAI's will perform the same for the most part when it comes to brands. The difference in power comes with the tune.
As far as popularity, and reputation of reliance, C&L, Steeda, and
Saleen are good names. Actually JLT is a top name too.
Saleens are more pricey but I have yet to see people
getting more power from a Saleen CAI vs. the other brands.
Old Oct 3, 2011 | 06:10 PM
wetwille3's Avatar
wetwille3
Originally Posted by Blacksmoke
I would not think it was the intake.
The handheld tuner probably is not the problem either.
I'd still say it was the tune if I were guessing.
UNLESS somehow they sent you the wrong CAI without anyone noticing it and it
was actually a different size CAI than everyone thought. That wild shot would explain why you would have trouble with two different tunes if it were true.
I don't think thats it. I initially had Breenspeed tune it. I had the problem with them. So i switched to Bama. Had the same problem again, I even contacted them and they checked the tunes. all good.
Ive cleaned the MAF and TB and had the dealership check the car at stock..It has to be the SCT or CAI
Old Oct 3, 2011 | 06:31 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
If its not the tune then it is a really weird situation.
That's why I think you should make sure JLT sent you the RIGHT CAI.
What I am saying is if the company sent you the wrong CAI, then
the tunes would not work because they were tuned for a different size intake.
Many of the CAI's look the same when they are not the same size.
I know its a mistake that would not happen often needless to say.. but you might
see if you can get the serial number off the CAI or model number and look it up
to confirm it is the right size CAI.
I really don't see how it could be the hand held tuner.
Most of the time if people have problems with these it is the tunes
not loading at all and usually is a problem with the initial key code for
the car not allowing the tunes to upload to the car.
I mean this is really a weird problem.
That's why I threw out perhaps a chance of a wrong CAI being delivered.
Old Oct 3, 2011 | 09:52 PM
wetwille3's Avatar
wetwille3
Ok I will do that. Ill check tomorrow and see if its the wrong one. Comparing it to the picture on the site, it look correct. But it has been 8 months since I ordered it and idk if the company will still send me a new one, if its the wrong one.
Old Oct 4, 2011 | 06:18 AM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Like I said many of the CAI's look the same even if they are different sizes so it is worth you checking just in case.
Old Oct 10, 2011 | 05:23 PM
wetwille3's Avatar
wetwille3
To all who care or has been following my car problems...I think I finally found the issue. I ordered a Steeda intake, so i needed to revise my tune. So i go to the Bama page to revise it. I click on the scroll down bar for intakes and realize there are TWO options for JLT intakes..The JLT and JLT 110. So i called Bama and asked which they tuned my car for..the answer was JLT not the JLT 110 (which I have). Well I sure as hell hope this fixes my problem.
Old Oct 10, 2011 | 05:49 PM
mayo's Avatar
mayo
That's the problem bro. The 110 would indicate a 110mm body on the intake, I would assume the other intake would be around 85-95mm and this difference would be the problem...get a new tune and keep ur fingers crossed
And to answer your question blacksmoke, the saleen is no different from a performance stand-point vs the CL I had on V before the switch...none felt anyway, but I do notice my engine temp stays down somewhat with the saleen and gives the 4.6l a wicked growl when you crack the throttle...along with superior protection from the elements compared to other intakes.
Old Oct 20, 2011 | 11:26 PM
JCON's Avatar
JCON
I plan to try the WMS intake. If nothing else the concept makes sense to me and it looks cool.
Old Oct 22, 2011 | 11:51 PM
wetwille3's Avatar
wetwille3
The new tune did not work. I have a Steeda coming so ill see how that goes..
Old Oct 23, 2011 | 08:22 AM
mayo's Avatar
mayo
Dude that sucks, and sorry to hear you got no fix. I thought for sure that would have fixed it. Who is gonna handle the tune with the steeda?
I always hear that it is good to stick with a tuner in the same climate as the car being tuned...might want to keep that in mind as you are in texas.
