Fail safe mode
Old Sep 21, 2011 | 06:17 AM
56TBird's Avatar
56TBird
Default Fail safe mode
I have a 2005 mustang that occasionally goes into fail safe mode. It generally happens on hot days. The temperature gauge doesn't register higher than on cooler days. Three service codes show up diagnostic memory.
U1900-ABS
P2106- Throttle actuator
P2135- Throttle position sensor
Can anyone help with suggestions on any of these causing the problem and if a component should be replaced?
Old Sep 21, 2011 | 03:07 PM
hammeron's Avatar
hammeron
in your shoes, i would be tempted to pull a throttle body from
a wrecked 05/06 Mustang and install it.
Old Sep 21, 2011 | 05:20 PM
cutthroat_army86's Avatar
cutthroat_army86
Default i got ur fix
I had the exact codes you have, and my car was in engine fail safe mode.
I took it to Carmax, they replaced the TPS and BAM, no codes, no engine failsafe mode. Hope this helps.
Old Sep 22, 2011 | 12:44 AM
tx_zstang's Avatar
tx_zstang
TPS or Throttle motor going bad on you. Check the 2 connectors to the throttle body for proper installation and retention.
Also, clean the throttle body with appropriate cleaner (do a search for more details).
Old Oct 7, 2011 | 07:33 AM
jhart33's Avatar
jhart33
I had the same codes. I took off the intake where it connected to the TB, got a rag and some gasoline and cleaned the inside and outside of the butterfly's. Never has the problem since.
Old Oct 11, 2011 | 01:29 PM
n406c's Avatar
n406c
I had both p2135 and p2106 show up after my car went into fail safe mode. A new tb sensor fixed it. A month later no codes, no problems.
Old Oct 11, 2011 | 01:37 PM
n406c's Avatar
n406c
http://www.trademotion.com/partlocat...layCatalogid=0
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
whatsup62
Sep 3, 2015 01:38 PM
