!!!..somebody help..!!!
Old Sep 29, 2011 | 10:05 AM
The S.t.A.n.G's Avatar
The S.t.A.n.G
Default !!!..somebody help..!!!
hi,
i have a serious problem with my 06 stang gt AT
my stang mod is
engine:
127500 comp cam with comp springs and comp phaser
ported heads 2.75
k&n cai
bbk 62 mm throttle
steeda spacer
ford racing intake manifolds
cmcv deleted
steeda ud pully
transmission:
tci master overhaul kits
hyden transmission cooler
exhaust:
pacesetter long headers steel
magna flow tru x-pipe 3"
corsa touring cat back
feul sys. :
inj. size 32
shelby gt500 feul pump
ratio:
ford racing 3.73
suspinsion and wheels:
intrax sys.
energy bushing front and rear upgrade
stock wheels with michellan tiers 235-45-r17 front, 245-45-r17 rear street tiers
tune:
sct x3 tuner
now the problems is:
from idle rpm's to 3000 rpm's very heavy launch with low and full throttle.the rear wheels doesn't spinning even when i used the break with gas til 2000 rpm's
i saw on youtub some stock mustangs with low mod do in 1/4 mile 12.6 sec no there is another one do 11.7 but my stang with all thats parts do in 12.35 109 mile.shocking isn't and that's not at all my stang launch from 0-60 in 4.65 sec and from 0-125 mile in 20 sec.this is rediculess the stock stang with 4.10 do it in 4.7 sec and to 100 mile in 18 sec. sometime i told my self sell your car and sometime no maybe there is a soulotions to ur problems..btw the sct tuner told after daigno. there is no dtc's..what u guys think the problem is? any solotions..plz...HEEEEEEEEEEEEELLLLLLPPPPPPPP
Old Sep 29, 2011 | 09:16 PM
The S.t.A.n.G
hallooo..any body?
Old Sep 29, 2011 | 09:29 PM
Nuke's Avatar
Nuke
Just having a TB spacer makes me want to say FAIL...
Old Sep 29, 2011 | 09:35 PM
Nuke's Avatar
Nuke
Seriously, whose tunes are you running? Many of your mods are worthless for power on a NA engine but for the ones that DO give you gains, you should be turning in much better numbers. Personally, I think some of those mods could be hindering you if they're not set-up properly and the tune must be written precisely for most of your mods (which leaves little margin for error compared to someone that's bone stock with just a CAI & custom tune).
Old Sep 29, 2011 | 10:47 PM
808muscle's Avatar
808muscle
12.35@109 Whats wrong with that? Tires wont spin? ......did they always spin after the cam install? After my cam install I couldnt get the tires to spin at all. Thats how much low end I lost.
Old Sep 30, 2011 | 07:16 AM
Nuke's Avatar
Nuke
Wow, I need my eyes checked. When I read that last night I thought I saw 13.35.
Old Sep 30, 2011 | 07:21 AM
scott4.6's Avatar
scott4.6
well id say your throttle body is to small. thats about same size that came on the npi 4.6.
Old Sep 30, 2011 | 08:25 AM
The S.t.A.n.G
hi guys
thanx for responding
first bbk throttle size 62 mm the stock one is 55 mm
whats is bigger?
second before this cam i used stage 2 comp cam and my stang spin til third gear
then small spin in 4th gear
i do from 0-60 in 4.21 sec with sc tuner..no bbk..no steeda..no intake manifold
this is strange i suppos gain more power with this parts.
so what shall i do? any ideas?
Old Sep 30, 2011 | 08:48 AM
scott4.6's Avatar
scott4.6
i just now relized you have a 06, yours has the dual tb, right?
Old Sep 30, 2011 | 08:53 AM
The S.t.A.n.G
btw
with my firse mod
kn+summit pully+amarican racing short headers+corsa catback+ford racing sparks+accel coils+superchips tuner
0-60 in 4.67
1/4 12.78@103.12
stock wheel and tires on the pp street
