Cooling mods/Boost?
Old Dec 6, 2011 | 03:21 AM
stealth_GT's Avatar
stealth_GT
Default Cooling mods/Boost?
When it comes to longevity, boost, and the stock motor.. would it be smart to focus on "cooling mods" in order to avoid detonation?
I was thinking about doing the following mods when I get t the R2300 down the line;
8 psi (maybe 10)
AFCO dual fan heat exchanger
Granatelli Aluminum Radiator
Killer Chiller (A/C supported cooling system drops Intercooler temps by 55 degrees)
http://www.killerchiller.com/about.htm
Granatelli Motorsports coils rated at 45,000 volts
(to get the most spark, kinda overkill, I know lol)
180 thermostat
90 octane canned tune (yeah, I know.. but it's all we have up here)
Is it possible to have too much of a good thing? Like the temps being "too cold"???
Not trying to run 500+whp on the stock motor, more like keep what I got and have it stay cool, reliable and all in one piece at 440-450whp..
My V3 would run hot after a few runs and low 12's turns into mid 13s REAL QUICK lol
Old Dec 6, 2011 | 11:28 AM
tbar's Avatar
tbar
I'd pass on the aftermarket coils there's no benefit & I've heard alot of issues with them. I don't think there's such a thing as to cold.
Old Dec 6, 2011 | 11:44 AM
onederful100's Avatar
onederful100
simple and cheap is a IC reservoir that you can drain and fill with ice water for the track.
on the street, my HO Whipple kit never had any overheating issues.
Old Dec 6, 2011 | 10:05 PM
Riptide's Avatar
Riptide
AFCO dual fan, upgraded IC pump. That's all I would bother doing if I were you.
+1 stick with stock coil packs.
Old Dec 6, 2011 | 10:07 PM
stealth_GT's Avatar
stealth_GT
Yeah, I figure, keep it simple rather than over the top
Old Dec 7, 2011 | 08:53 AM
moochman4life's Avatar
moochman4life
I'd love to give you some first-hand experience with the benefits of water/meth, but I can never find any time to finish installing the damn thing.
Old Dec 7, 2011 | 03:36 PM
Diabolical!'s Avatar
Diabolical!
The GMS coils were crap for me. Failure after failure.
Old Dec 7, 2011 | 09:00 PM
tx_zstang's Avatar
tx_zstang
lol, same here...
What are you IATs like when you get into boost? If you're into cool air already, methanol might not help as much. Here in Texas, where it's 90+ half the year,
it makes a little more sense. Even so, when I had a vortech and a/a fmic, I'd normally see iats only a few degrees above ambient. But it definitely liked cooler air, as does my KB now.
Old Dec 7, 2011 | 10:26 PM
908ssp's Avatar
908ssp
Engine water temperatures and IATs are pretty much independent. Best for the enigne is to run a constant 195degrees just like the factory thermostat. Do everything you can to keep the IATs down. But running the air conditioner seems excessive plus that will put more heat in the motor and lower gas mileage.
Old Dec 8, 2011 | 09:08 AM
moochman4life
Originally Posted by tx_zstang
lol, same here...
Ripping around town on a hot day, my AITs don't usually get above 110 or so. However, out on the track, I've seen them climb as high as 140...but that's 20-30 minute runs, 4 times a day, sometimes with only an hour and some change to cool down...and maybe some runs through the skid pad mixed in.
That's why I need to finally finish my water/meth: keep the car running efficiently during long runs to max hp/tq (prevent excessive loss due to a hot *** running car, really).
