Rough Idle in Cold Weather
My idle is usually around 800RPM. Anytime the weather gets below about 60 degrees the idle drops down to 500 and back up to 800-1100. On occasion the car stalls while stopped at a light because it will get as low as 300RPM and stall.
I'm thinking the throttle control sensor maybe? Dirty TB?
Suggestions are welcome.
I would try cleaning the Throttle Body,and disconecting the battery for a while to give the car a chance to reset itself. If that doesn't work, then you might want to look into replacing the Throttle Position Sensor on the throttle body.
