Idle Searching
Old Jun 2, 2012 | 10:59 AM
rocky321's Avatar
rocky321
Default Idle Searching
08 GT. 121000 miles. When starting up from cold, the idle searches high/low. When initially taking off to drive, the engine bogs down, unless you get on it. Once its warmed up, that sympton is gone until the next morning/cold start. No codes and could not locate any vacuum leaks. Throttle body removed, cleaned and gasket replaced. New fuel filter.
Old Jun 3, 2012 | 12:43 PM
Nuke's Avatar
Nuke
Stock tune? CAI?
Clean the MAF next and run a tank or 2 of SeaFoam. 121k miles is a lot for an '08 and hopefully it was mostly highway. Any other maintenance records? Last time plugs were replaced? Sounds like a (whichever-loop-mode-its-in-when-cold; can never keep them straight) loop issue.
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dokilar
15
Oct 16, 2015 08:13 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
