Looking to exceed the 500rwhp barrier..
m90
VMP Pulleys
Steeda CAI
VMP Tune
Aluminum 1 piece driveshaft
Mac Long Tube Headers
Mac Prochamber
Roush off road mufflers
StopTech big brake kit
Roush Stage 3 Suspension
FRPP 3.73 gears
The rest is just visual
VMP Pulleys
Steeda CAI
VMP Tune
Mac Prochamber
FRPP 3.73 gears
Ok, so lets pretend your goal is 650.
Sell the M90, super lowball, 2k in your pocket.
Pickup a whipple, or KB2.6/2.8. Lets say new - $6k
GT500 fuel system - $700
Forged rotating assembly from livernois - ~$2k
Total so far - $6700
Will you be doing all the work yourself?
Heads/cams - $2000
Total $8700
That will get you to your 650 mark with the right pulley no problem. Tack on another $500 for a tune and you're good to go. You may want to send off the input shaft of the tranny to get hardened, but there is no need to replace it with a 6sp.
I'm just saying it can be done for 10k. If you're a member on S197, there is a good read for a guy who wanted 800+rwhp. If you're not a memeber, you should join and read it!
I'm 99% sure you'll say you want 650. 9 out of 10 people that do crazy builds always say in the end "I should of stayed with 450rwhp / 550rwhp / 650rwhp"
My .02
Heads/cams - $2000
Total $8700
My .02
A long block with fully ported heads and cams with a solid forged bottom end with no Chinese parts will cost you at least $8000. Then the supercharger is 6k. What about your tranny? You have a heavy conv. Pull one hard shift and you are picking up your input shaft. Pulleys, balancer $800. Heat exchanger $700. Fuel system. $1100. Throttle body $600, (kb stage II TB blows)Upgraded diff... Then add on $2000 in nonsense you didn't think about.
Unless you are ready to drop another $17k at least don't do it.
I am in for $33k in mods without labor. I still didn't do my tranny, rear and long block. I have 20k on the side for 650 rwhp with a Magnum XL and new rearend. I might not do it now that I see the power the 2011 and up GT's make with a SC.
That is reality. if you don't do it right you are wasting your money because you will just break it.
There are quite a few guys running 600-650 with a stock block, but forged rotating assembly. If he wants to go to the 800+ range, he'll need new everything!
The blocks in these cars have been known to handle a pretty potent amount of HP when they don't have crappy stock rods being tossed through them.
Well, yes. The iron BOSS blocks are pretty damn strong, and they come in big bore so you can go 323ci on those guys. Other option would be the Aluminator from Ford. If you can find one, since I'm 90% sure they stopped making them
