Evans waterless coolant?
Has anyone heard about this coolant? I saw it advertised on a show on speed tv. I was always told to mix coolant with water for best results. and this stuff is expensive also, So i dont know if it would even be worth it, or if it would even cool your system any better. what are your thoughts.
Are you experiencing heat-soak issues? There is an additive that one of the members is using that I believe reduced his coolant temps by more than a few degrees but I can't recall the product.
Frank
No im not having problems, just saw it on tv, and they made it sound like it's alot better that the normal 50/50 you get. the only thing that really cought my attention was the no corrosion. Just though I check and see if anyone has actually used it. just curious.
Sep 16, 2015 07:53 PM
