New Diff Cover
Old Jul 29, 2012 | 04:17 PM
rocky321's Avatar
rocky321
Default New Diff Cover
08 GT. 150,000 miles. Going to replace rear end fluid and might as well replace the diff cover with one that has fill/drain plugs. I notice most covers have the load bolts for the bearing caps??? How do these work exactly? And how can a diff cover take the load?? What covers are you guys using? Car is stock by the way.
Old Jul 29, 2012 | 05:09 PM
danzcool's Avatar
danzcool
I don't know enough to say how they work exactly... but the stock cover is stamped steel, the covers you are looking at are likely cast aluminum with strengthening ribs built in, it doesn't flex like the stamped steel, that's how it can take some of the load.
Old Jul 29, 2012 | 05:20 PM
moosestang's Avatar
moosestang
The load bolts are pretty simple. You screw it in till it makes contact with the caps, then torque to 5 ft lbs or so. I don't remember the exact directions, but it puts pressure on the caps.
Be sure to use some type of anti-seize on the plug threads. My drain plug is seized up good and tight. I broke a 1/4 inch hex bit trying to remove it.
Old Jul 29, 2012 | 05:41 PM
rocky321's Avatar
rocky321
Any one brand in particular? Load bolts sound easy enough
Old Jul 29, 2012 | 05:53 PM
6-Speed's Avatar
6-Speed
The Ford Racing Cover is a good one; it's the one I have on my car.
Old Jul 29, 2012 | 07:17 PM
moosestang's Avatar
moosestang
I have the ford racing one that 6-speed just posted. The load bolts are more for the lower gears, because they put more pressure on the bearing caps. I'm no rear axle expert, this is just what I read when getting 4.10 gears installed.
Old Jul 29, 2012 | 08:26 PM
6-Speed's Avatar
6-Speed
Another benefit of the FRPP cover is that it increases the oil capacity, which perhaps helps with cooling. Be advised that you still have to fill the oil to a level based on the front fill hole on the pumpkin and not the one in the cover since the one in the cover is higher than the front fill hole.
Old Jul 29, 2012 | 11:04 PM
tx_zstang's Avatar
tx_zstang
I use a LPW; clears the panhard bar just fine.
The bearing cap bolts are torqued to 10 ft-lbs, as are the locking nuts.
Having the drain and fill plugs are really nice.
Dont forget to add some friction modifier when you change fluid.
BOB ROME
Jul 26, 2023 01:54 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
prophotog
Sep 15, 2015 08:38 AM
