Forged internals? Help
Old Aug 1, 2012 | 11:10 AM
chevybeater's Avatar
chevybeater
Default Forged internals? Help
So my goal is to get my car to 600bhp with centrifugal boost, I was wondering where I could get forged internals and wich parts do I have to change, could I change pistons and rods and survive or do I also need the crank?
Old Aug 1, 2012 | 11:29 AM
siggyfreud's Avatar
siggyfreud
Pistons and rods are the main key components. But when it's apart, don't skimp, do it right, and swap the crank as well. Never know when you'll want MORE power.
Brenspeed and JDM have forged rotating kits I believe. AM might as well, but I've never looked.
Old Aug 1, 2012 | 01:57 PM
Tanner05's Avatar
Tanner05
Chop Mod
modmax also has some good options for rotating assemblies.
Old Aug 1, 2012 | 02:52 PM
xkape's Avatar
xkape
Corrcet me if wrong here, the rotating assembly is basically a DIY forged engine yes? I mean, other than 0 miles on the engine, is there a difference between Brenspeeds stage 2 rotating assembly and a B326 or B302? Pardon the ignorance, it happens.
Old Aug 1, 2012 | 09:15 PM
retfr8flyr's Avatar
retfr8flyr
A rotating assembly is just that, Pistons, rods, crank that you would have a machine ship install in your block after it was machined. The B326, B302 are complete shortblocks that have had all the machine work done and are fully assembled. The cheapest way to go, for 600 hp, is just get a set of rods and pistons and use your stock crank. The stock crank is good for about 650 hp as long as you keep the RPM's below 6500. The stock crank is plenty strong it just doesn't have the extra balance throw, that the forged crank does, so it doesn't like high rpm.
If you find a local machine shop, that knows mod motors, you can get this combination built for under $2000.
Earl
Old Feb 26, 2013 | 01:06 PM
barspeedhollywood's Avatar
barspeedhollywood
Livernois Forged rotating assembly for 3valve 05-09 Mustang GT
$1499
http://www.livernoismotorsports.com/...ssemblies.html
Old Feb 27, 2013 | 06:22 AM
Scott2's Avatar
Scott2
Firstly, there is no cheap way of getting 600 HP from a 3 Valve or everyone would do it!
I have a similar goal and am currently assembling a new engine. I elected to go with a built forged short block for a couple of reason; firstly keep the OEM intact for a spare and secondly I was not aware of a local machine shop that had a solid reputation and experience with building a 3V. While this list of parts is specific to my build it will give you an idea of what is required. And yes of course do not forget the fuel system.
• FRPP 4.6 Liter Aluminator Short Block 9.8:1 Compression Ratio, M-6009A463V – Inventory
• FRPP 4.6 Liter 3V Performance Intake Manifold, M-9424-463V – Inventory
• FRPP 4.6 Liter 3V 62mm Billet Throttle Body, M-9926-3V – Installed
• FRPP High Flow Fuel Injectors, Flow Rate 60 lbs/hr @ 39.15 PSL, M-9593-LU60 - Inventory
• FRPP CNC Ported 3V Cylinder Heads , M-6050-463VP3 (LH) and M-6049-463VP3 (RH) - Inventory
• FRPP 4.6L 3-Valve Cam Phaser Limiter Kit - Inventory
• FRPP Performance Head Gaskets, M-6067-3V46 - Inventory
• FRPP High Performance Oil Filter, M-6731-FL820 – Inventory
• FRPP 3V Header Gaskets, M-9448-A463V - Inventory
• ARP 4.6L 3-Valve Head Studs, 256-4202 - Inventory
• Moroso Performance Parts Ford Modular 7qt Capacity, 6 ½” Deep Sump Oil Pan, 20548 – Inventory
• Canton 4.6L / 5.4L Oil Pan Stud Kit, CAN22-364 – Inventory
• Ford OEM Oil Pan Gasket, 3L3Z-6720-AA - Inventory
• TSS 3V/GT500 Oil Pump Assembly w/ Billet Gears - Inventory
• Vortech 6 Rib Supercharger Pulley (2.87”), 2A036-287 – On Order
• Comp Cams XFI™ SPR Ford 4.6L/5.4L Modular 3V Cams (Springs and Phaser Modifications Required), 127550 – Inventory
• Freedom Racing Tool & Die 3V Valve Spring Compressor, FR-303-1039-TD
• FRPP 4.6L 3C Camshaft Drive Kit, M-6004-463V – Inventory
• Ford OEM Cam Phaser Bolts, 2 @ 3L3Z-6279-DA - Inventory
• Ford OEM VCT Housing Gaskets - 3L3Z-6C285-AA Right Hand and 3L3Z-6C286-EA Left Hand - Inventory
• Ford OEM 2 Valve Steel Bodied Tensioners, F6AZ-6L266-DA Right Hand and F6AZ-6L266-CA Left Hand - Inventory
• Ford OEM Timing Cover Gaskets, 4R3Z-6020-BE, 4R3Z-6020-DB, 4R3Z-6020-EB - Inventory
• ATI Harmonic Balancer – ATI Super Damper Serpentine Series, 918039 – Inventory
• ARP Harmonic Damper Bolt M12 x 1.50 x 53mm, 206-1001 – Inventory
• Ford OEM Crankshaft Key, FLAZ-6B316-AA – Inventory
• Ford OEM Front Oil Seal, XW4Z-6700-AA - Inventory
• PRW SFI 3V 8-Bolt Flexplate - PRW Platinum Series SFI-Rated Steel Flexplate, 1828111 – Inventory
• ARP Flexplate Bolts (8), M10 x 1.00 (UHL .800), 254-2901 – Inventory
• UPR Billet 3 Bolt Tensioner and Custom Billet 76mm Tensioner Pulley - UPR 3030-02 and Carmen Goudey S197 76mm Pulley - Installed
• ARH Mustang 3V 2005-2010 Stainless Steel Headers1 ¾” Primaries w/Catted X-Pipe, MST0634WC - Installed
• Mangnaflow Ford Mustang GT, Shelby GT500 3 inch Cat Back Exhaust, 16674 - Installed
• Stage 8 Stage 8 Locking Header Bolt System 8mm, 1.25x22mm, 8906M – Inventory
• Circle D Specialties 5R55 Multi Disk 245mm 3000 Stall Performance Torque Converter - Inventory
• Performance Automatic 5R55 Deep Aluminum Pan and Filler Tube Set , PA27455KT – Installed
• Performance Automatic Hardened Transmission Input Shaft for Ford 5R55S, PA27406 – Inventory
• TCI Auto StreetFighter Ratchet Automatic Shifter, 619570 – Installed
• TCI Auto Hi Performance Transmission Servo Kit, 3rd Gear Servo Kit, 576005 – Inventory
• TCI Auto Hi Performance Transmission Servo Kits, 4th Gear Servo Kit, 576006 – Inventory
• Canton Racing Products Automatic Transmission Expansion Tank, 45-000 – Inventory
• B&M Racing and Performance Products Hi-Tek Transmission Cooling System, 70297 - Inventory
• Hypertech Power Stat 160 Degree Thermostat Mustang GT (05-09), HYP1011 - Inventory
• Metco Motorsports Four Piece Idler Pulley Set, MIP-2005 – Inventory
• Meziere Enterprises 55gpm Electric Water Pump, WP346S – Inventory
• Meziere Enterprises Electric Water Pump Relay Kit, WIK346 – Inventory
• AFCO 2005-2010 Mustang GT Performance Aluminum Radiator, AFC-81281-S-NA-N – Inventory
• AFCO Dual Pass Heat Exchanger with Dual Fans, 80280PRO – Inventory
• Painless Performance Products Auxiliary Fuse Block with 7 Circuits, 70107 – Inventory
• Trick Flow Specialties Adjustable Crank Sprockets, TFS-51800505 – Inventory
• Trick Flow Specialties Cam Degree Kit, TFS-90000 – Inventory
• Trick Flow Specialties Cam Degree Supplemental Kit, TFS-90100 – Inventory
• Ford OEM Cam Followers (24), 3L3Z-6564-BA – Inventory
• Ford OEM Lash Adjusters (24), 5L1Z-6500-A – Inventory
Good luck!
Old Feb 28, 2013 | 10:02 AM
chevybeater
Wow,nice list,I aint giving up yet,aprox what does that list cost?
Old Feb 28, 2013 | 11:10 AM
Simon1's Avatar
Simon1
If i were to build a short block, I wouldn't have it at 9.8:1 for a boosted application. It's doable, but not normal for bossted applications. Generally the boosted motors are 9.0 or 8.5. Please correct if I'm wrong. They used to make to shortblocks, one for boosted, one for N/A.
Old Feb 28, 2013 | 11:35 AM
Ford_Dude's Avatar
Ford_Dude
Ya if you are building it for boost then you go lower compression so you can cram more boost in.
But if you go to low then it'll have to have FI or it'll be really weak. so lowering the compression a little instead of a lot makes sense for those not putting boost on right away.
