Bent trailing arm mount on rear axle!?
Old Sep 18, 2012 | 07:06 PM
Justinsmt88's Avatar
Justinsmt88
Default Bent trailing arm mount on rear axle!?
The bracket/mount is bent to hell and I can't get the lca out of it. Any ideas on how to fix this? Do they sell weld on replacement brackets?
Old Sep 19, 2012 | 09:39 PM
Diabolical!'s Avatar
Diabolical!
Aren't you the guy who curbed his rear axle? If it did that much damage, you need a new rear axle assembly. Regardless of the damage to the LCA bracket, a hit that hard will have damaged your axle tubes at the very least and likely your axles and pumpkin guts as well.
Old Sep 20, 2012 | 01:30 AM
Lem-06's Avatar
Lem-06
holy damn, how long have you driven on that lower control arm?
agreed with diabolical, you should replace that entire axle assembly.
If it did enough damage you have to replace lca's, rotor, panhard, and sway bar, sorry but replace it all
Old Sep 21, 2012 | 03:27 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Yeah, that's bad news man.
One alternative would be to take the car to a shop who could remove the housing, cut and reattach the axle tube ends in a jig, and fabricate LCA mounts. You could get pretty trick with it and make multiple mounting holes. But keep in mind, this is racecar stuff. It wouldn't be cheap, but it would be cool!
I don't know where you are in Ohio, but I know Rogue Race Cars in Williamsburg can do that type of thing.
Old Sep 22, 2012 | 07:46 PM
moosestang's Avatar
moosestang
Hey! You've got that heavy weight thing on your axle and it looks bent as well. Mine doesn't have that, weird.
I would have just gotten a new takeoff rear axle.
mtgldr
Feb 3, 2024 09:00 PM
Nov 10, 2015 11:39 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
Dragonus18
Sep 9, 2015 01:21 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
