cooling fan
Old Oct 15, 2012 | 05:36 PM
blumax2007's Avatar
blumax2007
Default cooling fan
I have a 2007 GT/CS about a year ago the ground wire on the fan connector came loose and fried. I ran a by-pass for the ground wire around the connector, now I'm starting to overheat in stop and go traffic. Has anybody had something like this?? I'm thinking about by-passing the connector and running the fan to constant power so it's always running with the key on??
Old Oct 15, 2012 | 06:16 PM
Nuke's Avatar
Nuke
Rather than bypass the relay, why not find out what the problem is so it operates as designed? You really don't want the fan running when it doesn't need to.
Old Oct 15, 2012 | 06:19 PM
Diabolical!'s Avatar
Diabolical!
You don't want the fan running all the time.
Old Oct 16, 2012 | 07:21 AM
DTMR's Avatar
DTMR
yeah if the fan is always running then your car will never reach full operating temperature and thats bad for sludge/oil
Old Oct 16, 2012 | 11:31 AM
blumax2007's Avatar
blumax2007
not throwing any codes so I'm kinda lost from there, that's why I was asking if anybody had a similar issues..
Old Oct 16, 2012 | 05:18 PM
Nuke's Avatar
Nuke
You won't throw a code for a minor electrical problem on the cooling system.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 25, 2015 09:06 AM
