SLP loudmouth rattle
Old Oct 23, 2012 | 02:02 PM
cpelaez's Avatar
cpelaez
Default SLP loudmouth rattle
Having a really nasty rattle when low RPM. Please help. Exhaust hanger isnt in contact with anything btw.
Old Oct 30, 2012 | 10:59 AM
Steve349's Avatar
Steve349
try tightening the bolts that connect the rubber hangers to the car, and double check the clamp tightness, the borla axleback i have has a good portion thru the rubber and i never heard a rattle
Old Nov 1, 2012 | 04:15 AM
Ricardo's Avatar
Ricardo
My car had same issue. It was the passenger side rear hanger...it expanded enough after it heated up to contact the body. But it was really hard to find because even idling allowed it to cool off enough to go back into place just the slight amount it needed to stop rattling. The local muffler shop heated it up and just bent it back slightly to give it some more room to expand.
Old Nov 4, 2012 | 04:06 PM
7gtthrilla's Avatar
7gtthrilla
I have the same problem. It always seems to be after I get on it a few times and I've checked the hanger. But it makes sense ( temp of hangers )
Old Nov 4, 2012 | 07:18 PM
Nuke's Avatar
Nuke
I had a persistent metallic rattle around 1800 RPM after installing my FRPP Stingers. Turned out that a little more torque to the axleback pipe clamps resolved my issue.
Old Nov 18, 2012 | 11:17 AM
justin96gt's Avatar
justin96gt
my muffler deletes were the same way had to give a little more muscle on the bolts
Old Nov 18, 2012 | 02:11 PM
moosestang's Avatar
moosestang
Have you checked it when hot? How about under load? Obviously you can't check it under load, but my point is the exhaust moves after it gets hot. My tips will stick out an inch more when hot, so the whole exhaust is moving rearward.
Old Nov 18, 2012 | 02:55 PM
Nuke's Avatar
Nuke
Originally Posted by moosestang
...the whole exhaust is moving rearward.
Or maybe the chassis is moving forward!
Galactic
Apr 29, 2019 02:56 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
UrS4
Sep 30, 2015 10:13 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
tmdm
Sep 4, 2015 06:45 PM
