Do we need egr valves?
I know they shut off at full throttle, but it brings exhaust gases back into the manifold to dull down the combustion so it helps with the environment. But doesnt it also dirty up our engines? What are the benefits of it besides the environment? what is it used for?
Like Diabolical said, that's the pcv valve. An egr valve is bolted to the exhaust manifold on earlier mustangs and re-routes exhaust gases back into the intake manifold. Our engines are supposed to have a form of exhaust gas recirculation using the variable cam timing, but how that actually works, I do not know.
Every newish vehicle has a positive crankcase ventilation valve.
There is one on the driver's side that has been mentioned that goes to the intake manifold which does have a normal pcv valve inside the valve cover(I know since I cut mine out and removed it), and there is one on the passenger side valve cover that goes to the intake tube not the manifold which is completely free flowing with no pcv valve on it. That's it. No EGR at all on our cars...I believe the GT500 has an EGR set-up but not our 4.6 3v's.
